Exactly how restrictive are the LG4/LU5 exhaust manifolds?
Transmission: World Class T-5
Axle/Gears: BW 3.45
Okay, afew years ago I had a free flowing exhaust made for my '83 Crossfire. 2.25" ---> 3" y-pipe, going into a high flow 3" cat, ---> 3" pipe into 2.5" tailpipes.
Anyway, I kept the stock, restrictive, LU5/LG4 exhaust manifolds on. Just wondering how big of a bottle neck they are now. I'm not interested in headers, but I do have a set of L69 HO manifolds. Any thoughts on whether it's worth my time to install the HO manifolds on my CFI? Will that extra 1/4 inch diameter give me much in the seat of my pants?
Re: Exactly how restrictive are the LG4/LU5 exhaust manifolds?
https://www.thirdgen.org/forums/exha...-question.html
BTW, note that the 2 1/4 aren't really 2 1/4:
https://www.thirdgen.org/forums/exha...manifolds.html
JamesC
Axle/Gears: BW 3.45
Thanks James. I guess the other question which only I can answer is, if it's worth the 300 bucks in labor.....
Axle/Gears: BW 3.45
I think I'll try to get them on by the end of the week and report back. I have to say that I expected more from my expensive, custom bent, free flow exhaust. Maybe the stock 2" exhaust manifolds are what's holding it back. We'll see.
Car: Pontiac
This seemed like as good a place to post this as any of the other threads. This is what the factory L69 pipe looks like when you sawzall it. About 2.125" I.D. I have a set of 14071200 lh and 1407xxxx rh I'll sell for $25 + shipping. no air tubes, includes EFE that needs to have butterfly tacked to shaft (seems to hold vacuum).
Axle/Gears: BW 3.45
Okay, got them on. I haven't driven it very much yet, but two observations:
1) When you get past 2500-3000 RPM you can really feel it pulling harder. It also seems to require a lighter throttle to maintain speed while cruising.
2) It sounds different. With the LU5/LG4 manifolds and the aforementioned exhaust, it had a sort of flatulent sound to it. Like small pipes dumping into larger pipes, which in fact was the case. It has a more pleasant burble to it now.
Two more items. The stovepipe on the driver's side was eliminated, and the butterfly valve on the passenger side was eliminated with a new pipe fabbed to take it's place. It really feels like I need to upgrade to 3.42 gears now.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Here's a picture of the "top of the line" L98 with dual converter setup.
Looking at it out of the car, it seems way more low performance than it would in the car. (Not my pics, I have the L98 manifolds with single cat, which is even less performance)
Cleaning up the stock manifolds.
Of course, like many, I want the Dyno Don headers.
I can't comment on the LG4 manifolds. Don't have any experience with them.
Axle/Gears: BW 3.45
The N10 dual cat exhaust is what I really wanted. Mostly because of the way it sounds and how all the resonance and vibrations have been engineered out. Something that you can't say about some aftermarket setups.
After looking for a while, I of course found one locally one week after I had my shop custom bend a system from the manifolds back.
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
