Stock Exhaust Manifolds
After searching what seems for hours I have not been able to find the answer I am looking for. So....
Is there a difference in 305 and 350 factory 3rd gen exhaust manifolds? I need the best flowing manifolds for a SBC 3rd gen. Headers are out of the question. Everything behind the manifold is open to whatever I decide to use. So, from 82-92 what is the best flowing manifold? Casting numbers would be great as well. Not to worried about A.I.R. since I can take care of that. Any help is appreciated.
Info from an 8 year old thread:
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
Does this still sound right? The lower 2 being interchangeable. Kinda sucks because as of right now I have the 1985 305 "H" Engine.
82-83 305 Crossfire
88 350 L98 (VIN 8)
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Stock Exhaust Manifolds
Not sure if they would bolt up to the 85 heads you have, but if find out for sure. I have a set of L98 350 TPI exhaust manifolds off of a 91. Would sell em for $25.
https://www.thirdgen.org/forums/exha...-question.html
Oh, Vin H and G are both carbed cars so the swap was easy. IIRC, the TPI cars have at least one air tube that faces the wrong way--sorry, it was a number of years ago. Carbed cars use a butterfly valve between the manifold and Y pipe on the pass side, while the TPI cars use a simple spacer, essentially the same piece without the butterfly.
JamesC
I bought some that were supposed to be L98 350 TPI, but were 2" outlet. Not 2.25 unless I cant use a mic or tape measure. I'm going to recheck them anyways then ask the seller what we can work out if they truly are 2". Does anyone have pics of the 2.25" so that I can share them when I look for more 2.25" manifolds?
IIRC (and I may not as I haven't looked at an OE manifold in some time), there's a part number cast into the manifold.
90-91 5.7L V8 (L98):
LH GM 14094063
RH GM 14094064
EDIT: Somewhere in the deep recesses of my foggy old brain, I seem to recall that the 2" doesn't quite measure that and neither does the 2 1/4.
The following link is interesting especially the last post:
https://www.thirdgen.org/forums/exha...manifolds.html
JamesC
LH GM 14094063
RH GM 14094064
JamesC
1 Post
Axle/Gears: 3:42
B.S. , those manifolds i sold you were bolted directly up to my stock 2 1/4 inch dual ypipe. I even sent you the cut ends off of the dual ypipe with the flanges so you could use those to weld up to your stock ypipe if need be. I am not a scammer!
Never said they weren't
Planned on it after finding out what others measured to see if it was a case of rounding. Re-read my post.
I will and thank you for the suggestion.
This could have simply been someone posting a difference in size, I would have remeasured and assuming they measure roughly 2.18 I would have posted that I mismeasured and no harm done and NO public attacks that I certainly don't appreciate. I didn't put names to avoid conflict until I found where the discrepancy was.
End of rant.
End of rant.
1 Post
Axle/Gears: 3:42
Well, i responded cause whatever you posted that time came directly to my personal e-mail.
I said I will double check. I will knock the carbon off the inside of the manifold and remeasure. Chill. U made a big deal out of this by letting the entire forum know that it was you. I often forget why I dislike forums. Thank you for reminding me.
And, when I remeasure I will let everyone know what I find. 2", 2.18", or 2.25". If I am wrong, I can admit it. I will post what I find.
Due to an extremely busy day at work, I did not get them measured. Tomorrow I will be at a meeting but will try to swing by for a measurement.
Correct, they are. Thanks for the info on this.
Measured 2.10" and 2.17"-1 is closer to 2" than 2.25" and the other is just the opposite. I guess tolerances weren't so tight on this type of item especially sine they were on the same car as stated by seller earlier.
Thank you all for the help because I would have considered this 2" (and wrongfully did) due to the fact that aren't truly 2.25".
Transmission: World Class T-5
Axle/Gears: BW 3.45
Can we assume that the 2" manifolds may be more like 1.93" or something?
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
no offense dude but i dont see why anyone would want to go through all the trouble to swap out their factory manifolds for other factory manifolds that might be just a tad better but still suck compared to any header out there.... all third gen manifolds are horrible regardless of which engine they came from and if your looking for performance then manifold swapping would be the last thing to do.. imo you just wasted alot of time and money just to swap out to "better" factory manifold that are a quarter of an inch bigger... why complain over manifolds that still suck..... you were way better off getting shorty headers at the least...
Axle/Gears: BW 3.45
Well, I guess that depends on what you want. Sure, on a stock car, you probably get another 15-20 hp from headers. But some people just want something better than what they have, with a stock look and without the hassle of headers. I just put a set of L69 manifolds on my LU5, so I guess I'm one of those folks.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
For some, performance is the only consideration so headers are the only way to go. For the rest of us, there are more things to consider. Headers have a lot of negative drawbacks, so we use manifolds.
By the way, I just did some exhaust work on an 88 LB9 5 speed. Used the Magnaflow 16450 Y pipe, a Walker 15622 Converter, and a DynoMax 3" catback. I highly endorse this setup if you want to keep stock manifolds. It fits great, sounds great, and I can feel a bump in performance at all RPM's.
Axle/Gears: BW 3.45
Just curious, how much does a set up like that cost?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm in Canada, so it cost a fortune.
My estimate would be approximately $350 for the Y pipe and converter. Not sure on the catback because the one I got is used. Any 3" mandrel bent catback would be the way to go on this setup. Personally, I prefer the sound of a Flowmaster, but this DynoMax sounds better than I expected.
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Seems like too many problems are caused by them. I don't race and this is my daily driver so I'm not even going to bother putting new headers on the bird.
Axle/Gears: BW 3.45
I already had a a 2.25" Y-pipe into 3" exhaust made for it and attached to the stock 2" LG4/LU5 manifolds. The L69 exhaust manifolds changed the way the car sounds, (for the better), and gave a perceptable increase in performance and driveability. It feels freer revving now, like it really wants some more gear, like a 3.42. I think if Crossfires came from the factory with the full L69 exhaust, (let alone it's gearing and 5 speed), people would look at them differently today.
Thats good to hear. It seems like these engines have a bit more potential than most people give them credit for.
When we had our LG4 rebuilt, my dad opted to install the L69 camshaft (because thats what I did on my 86 LB9) and eventually upgraded to a 3" catback exhaust. It definitely has some pep to it, but it feels as if its been choked somewhere.
I just converted the alternator to a 140amp CS-144 and its running really well. I guess the next step is to hunt down some high output manifolds, an EFE valve and a nice Y-pipe.
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
dont jump the gun,you should use your eyes and your brain in equal parts and leave the mouth out of it
transaero
08-31-2015 01:14 AM
