Installing a new exhaust pipe
Hello,
I have a 1984 Chevy Camaro with a V8 engine. I replaced the exhaust pipe (after the cat) last year when I tried to get an inspection sticker. The only way I could get it in myself was to cut it, put it in, and then use some adapters to reconnect it. The problem is that this year the pipe on one side of the adapter fell out and got really banged up. I bought another whole pipe, but rather than cut it again I want to install it whole. I jacked the Camaro up as far as I could get it and I could not get the pipe over the wheel thing. Is there an easy way to get it in without paying someone to put it on a lift and install it for me?
ANY help is greatly appreciated.
Adam
Adam
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: Installing a new exhaust pipe
u have to jack up the body and let the rear suspension hand down then you should have plenty of room
Car: 92 rs
Transmission: 4L80E
yeah its easy to do.. but if your not to sure id take it to someone. Nothing worse than have a car fall on ya
Car: 92 rs
Transmission: 4L80E
no i dont have any diagrams.. i always jack mine up lifting the suspension and all... then put jack stands right in where the lower control arms connect to the body and let the weight down on the jackstands and hte suspension will unload and hang (not responcable for any accidents or damage that may occur if you try this and get hurt or break something)
toronto formula
11-10-2015 06:17 AM
transaero
08-31-2015 01:14 AM
