Hedmen Headers
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Hedmen Headers
Well, I got a set for 40 bucks. I was trying to get the driver side in first and the k-member was in the way. I grind about 1in to 1.5 in on somespot. I still can't get them to fit, so will new motor mounts help? When I get them in I got about 2in of ground clearance.
Also, what kind of motor mount will I need? Can i get some cheap one at autozone for 10 bucks?
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
Longtubes, I bought some solid motor mounts. I'll have to put them in, in a couple days.
Re: Hedmen Headers
I put long tubes on my '82 T/A 305, they are a pain. Those cars weren't meant for them, I hammered mine in a tiny bit, but my ground clearance is terrible. I wish I had sprung for shorty headers and ran some 3 inch tube back to a more open, muffler friendly location.
Car: 91 rs
Engine: 305 tbi
Re: Hedmen Headers
idk how mine got put on i had them installed for the simple fact i knew it would be a bitch but u only have 2in ground clearnce thats rly low i have hedmen lt and i have atleast 5in or so which i still think is too low. heres sum pic of mine might not be much help sry
Re: Hedmen Headers
Car: 1990 Camaro ZRS
Engine: 350 SBC
Re: Hedmen Headers
i had to get my hedman lt's on by jackin up the the motor itself. i hear that others have tried from underneath. and i had hard time with that too. it was a pain. lol good luck!
Car: 91 rs
Engine: 305 tbi
Re: Hedmen Headers
make sure when u do get them to fit u use good gaskets ive had a horrible time with a leak cause the gaskets r bad and the header might be warped i have a small one now in the middle of the header u can see the gasket moving i guess its a bad paper gasket or shop didnt install right im having a time tryin to figure out how to fix it without having to take pff the header
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
Yeah, I should get my new motor mounts in tomorrow..I'll have to jack the car up and take the a-arm off to get the motor mounts off. I'm going to run 2" duel exhuast the rest the way out.
Car: 91 rs
Engine: 305 tbi
Re: Hedmen Headers
yea its good ur doing the motor mount i got my car back today still got a leak but not bad it sounds sic but when im driving and get to a light and come to a stop there is a very annoying and loud shaking whic im assuming is the motor mounts tht r bad gotta check this week end and see
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
I started the motor mount and everything about 10. I never took a A-arm off before so it took me a while to get it off. It was a B**ch to hold the motor mount nut and turn the bolt but I got it. After I grind about 2 1/2 hours and putting the headers in and dropping the motor, I think I put the headers in and out at least 12 times. I only put in the drivers side for today taking about 4 hours. I only have about 1-1/2" of ground clearance but the speed bump gave me about 2-1/2" now if not sure. When I turned the car on the sound was priceless. I love the loud, I just can't wait to get the duel exhaust hook up.
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
I don't think something is right here. I had to cut about 3 in off the A-Arm and maybe 1/2 in into the K-member on the passenger side. It took me probably 4 hours to get everything cleared on the passenger side. I don't know if my 4 speed manual to th350 swap helped any, I used the same cross member. When I get paid I'm going to buy a new transmission mount bushing and see if it lifts the tranny up a little so I get better ground clearance. I heated the heater up with running the car for 30 mins then took a jack and lifted the headers up to get a couple of inches of ground clearance. I'll have to take a pic and post it here.
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
Yep, I got maybe about 1 to 2 inches of ground clearance. I'm going to buy a new tranny mount and see if I can get the tranny lifted an inch or so.
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
I bought off some guy for 40 bucks who said they were off a camaro like mine.
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
Well, I guess now all I need to do is buy another set. All the clearance I did they should just slide right in.
Re: Hedmen Headers
He may not have been lying, like I mentioned before, I have longtube headers on my Bird. I have only slightly more ground clearance than ymenic's picture shows. These cars simply do not accommodate longtube headers. Since you have gone this far, I would suggest turning your exhaust clamps sideways and possibly cutting the flange off and welding the collector right to the header itself. Otherwise you may have to scrap the LT's and invest in some shorty headers and fab the rest.
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
Re: Hedmen Headers
Bought the hedman tubular exhaust system for my 84 and fit with no or little mods. No way would I cut the LCA and K member.
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
Re: Hedmen Headers
Take a look at mine........I still have some clearance
http://www.youtube.com/watch?v=dVraQYllNEE
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Hedmen Headers
Engine: 307
Axle/Gears: stock
Re: Hedmen Headers
Yep, you don't want to see my LCA or K-member on the passenger side. I just need some new rear and front spring to bring the car up a little bit and new tires and I should clear these speed bumps a lot better.
Car: 92 convertible camaro RS
Engine: 355
Re: Hedmen Headers
Try your best to look for copper gaskets they seem to be the best for lasting and not leaking once you get them seated on. usually takes tightening the bolts twice once on install and after you heat them up and drive a while. sure you probably know that but thought i might just say.
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Hedmen Headers
I had to remove the oil pressure sensor and bang a corner of the body a little bit along with a few dings on the headers but they went in fine.
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Hedmen Headers
No problems installing the 68460's here, no grinding or cutting needed, both required to be installed from underneath and driver just required removing the oil pressure sensor which i broke and had to be replaced and passenger side only the starter had to be removed and reinstalled.
Car: 1987 camaro z28
Engine: ramjet 350 crate motor
Transmission: t-56
Axle/Gears: 373
Re: Hedmen Headers
i had to remove my starter, other than that the headers went right in. and my ground clearance is pretty good, around 5 or 6 inches. im running the heddman long tubes into heddman s-tentions and summit glasspacks dumped under my seat. i dont know why people say you cant run true duals on a 3rd gen, mine are great
Car: 86 Camaro
Re: Hedmen Headers
It's been so long since I put mine in but I do know I didn't have to cut anything. As I recall the drivers side went right in, the pass. side was a little bit of a bitch but got it done.
LOL Glad to see I'm not the only one who knows about the wonders of flex pipe. I ran my exhaust true duals through flowmaster 40's with dumps and was constantly dragging them. Now that I don't worry about tagging or inspecting it I just run dumps on the headers uncorked.
Dan
Dan
Re: Hedmen Headers
when you have long tube headman headers. There S extensions are your best friend when it comes to the tranny cross member.
Buy some
http://www.summitracing.com/parts/HED-18701
Buy some
redformula88
10-14-2015 06:08 PM
