Headers for 1992 LT1
Car: 25th Anniversary Camaro
Engine: 383 LT1 Stroker
Transmission: Custom TH 350 w/ TCI Trans Brake
Axle/Gears: still looking for a rearend
Im wondering what i have to do to install a good set of performance headers on my LT1 383 Build since its going into a 92 body. ive been told that with this engine going into that body i will need to have custom built headers And Y pipes made, can anyone tell me if there is any truth to this? anyone ever done it that has some real life input on the matter?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Headers for 1992 LT1
The ones I make will work if you don't need smog gear.
nope. Don't need smog. God bless florida.
Car: 1987 Trans Am
Engine: LQ9/L92
you shouldn't need anything custom; the lt1 uses the same port spacing and bolt pattern as the standard SBC, so anything that works for the 305/350 will fit. dyno don does make some very nice looking pieces...
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i was just going to say.... don't forget about D port shaped exhaust ports, you'll need D port shaped headers.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
On the other hand would the use of a SBC header cause an issue if used on D port heads if the primaries were large enough to not cut off some of the port?
New2Chevy
09-28-2015 12:35 AM
