Piping
Piping
hey fellas i have a 89 trans am 5.7tpi and i was wondering can i run headers and straight pipe on this car or does the underbody design not allow it? also is the best exhaust system set up this car? i have no cat and my pipes come off the header down along passenger side to flowmaster muff and pipe
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Piping
There's no room to do it straight back the conventional way. You have to bend to clear the frame rails, transmission and crossmember.
Engine: 383 Carb
Transmission: 4L60
Re: Piping
It depends what headers and mufflers you want to use, and what sacrifices you're willing to make, really.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Piping
It's certainly easier to just run exhaust the factory routing.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Piping
True duals tucked the old way is possible, but requires a TON of work. I had to make everything myself (torque arm crossmember, modify my Spohn torque arm, make the exhaust, and make my the trans crossmember). But I do have near 8" of clearance at the X and 6" or so at the mufflers. And my car is on sportline springs with stock size tires. My collectors hang very low (3" or so) but unless I build headers from scratch, I cant do anything about that. My old headmans had much better clearance than my new Dougs. But the dougs are much better in everything else so they win.
Re: Piping
Engine: TPI 305/ v6
Re: Piping
I didn't have anything but stock parts to clear on mine (unlike yours). I did mod the original trans mount bar for extra clearance. Other than that (I used hooker shorties), it wasn't a lot of work. (I had hotchkis 2" drop springs at the time of pictures as well)
Engine: 383 Carb
Transmission: 4L60
Re: Piping
That's similar to how I did mne, over the axle on both sides with an H pipe nehing the crossmember.
One thing to keep in mind is that both the pictured setups have manual transmissions. There's no room between the trans and the frame rails on either side like that on an automatic.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Piping
If you use SFC like the Alston's you can run the piping and a bullet type classic cherrybomb down the outsides of the car, the valley where the pan and sides of the car meet has plenty of room to tuck them up there. no cross member to deal with, but the H - X would have to be right at the end of the headers, which isn't bad, your suppose to put it where you find the most heat. The trick use to be is spray paint the pipes after said headers n where it burns off first, is the key place. Or just run true duals.
Thats where mine is run, though I only have a single down the right side and the pipe runs straight out the back, no axle loop. Any bends just kills the high rpm band of the V6.
Here is an old pic, that door has been replaces. The CB hoook right onto the end of the Y pipe. They sound better closer to the engine, any enigne, my V8 car is the same but true duals.
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
LT1Formula
10-08-2015 08:34 PM
