in need of quiet exhaust..
1 Post
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
i have a vert iroc and dont want a loud system.. still want a low rumble but quiet at idle and can barely hear the rumble only when driving at high rpms.. magnaflow or flowmaster has to offer or anyone.. have heddman shorties with there y pip.. 2.5 system now need the muffle.. any suggestions?
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
Re: in need of quiet exhaust..
I've heard that hooker's aerochamber is pretty tame at idle but has a nice bark to it at wot
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have the Hooker Aerochamber and I like it - it's pretty quiet at idle, has nice noise when you expect it, flows really well, and is pretty inexpensive.
1 Post
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Borla is fairly quiet at idle with mild bark at upper RPM. Kinda heavy and expensive.
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
dynomax.
nice tone at idle and dosent draw any attention until i floor it.
i had a flowmaster and it sounded like i was doing a hundred just driving normal.and it had a horrible drone and it was worse with the tops off.
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
MAGNAFLOW quite very deep rumble at idle but will scream at wot.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Sounds like you want a stock exhaust lol
The flowmaster force 2 catback was pretty quiet when I had it on my car and sounded good.
Car: 87 GTA
My http://www.texas-speed.com one sounds like you are wanting. I have a LS1 cat-back Rumbler on my L98.
At cruise, there is barely a sound at all. Under slight acceleration & you know its there, but still not obnoxious at all. Go WOT and you KNOW it is there. Still not obnoxiously loud, but most definately know it is there.
Video taken at 170,000 miles, stock manifolds, Magnaflow hi-flow cat & the Texas Speed & Performance LS1 Rumbler cat back I listed above. Since my windows were down, you can hear all the wind blowing too. And no back seats at all, so that reduces potential sound barrier by just a tad, maybe.
I have a SLP 2otL cat-back on my bolt-on LT1 swap. Its a B-body LT1 so the compression is about the same as an L98 or typical iron headed SBC. Its pretty quiet, you can't hear it over the other cars at the line, and once past the 1/8th mile my car is near silent.
http://www.youtube.com/watch?v=Rajk2bZdrS0
Here's a sound clip of my LT1 going from zero to about 80mph, windows down so some sound is reflected from the wall. The whining noise you hear is actually my power steering pump, its a bit loud. http://home.comcast.net/~thirdgen89g...l_wot80mph.mp3
B-body LT1, iron headed 9.5:1 compression I think, B-body cam (smaller than L98 cam)
Moroso CAI
Hooker 2055 headers, SLP 2otL catback.
diana227vegas
07-08-2016 12:27 AM
dimented24x7
09-06-2015 03:51 PM
