best exaust system for a carbed 355 no cat
Car: '85 Camaro Z28
Engine: 355 carburated
Transmission: TKO600
Axle/Gears: GTA rear, 3.73 posi, hotchkiss
i bought an 85 camaro off a guy a few months back and now im started on the process of making it my own. ive been researching exaust for a while and i cant really figure out what i should get. its a 355, comp cams with shorty headers and since it doesnt have to pass emissions im not going to bother spending the money to run a cat. i want that loud cam idle and i want it to be loud and agressive but not earsplitting at WOT. something that wont drone. also preferably somethin would counteract the raspyness of a catless system
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: best exaust system for a carbed 355 no cat
Go with 2 3/4 pipe from headers true duals to and h pipe somewhere in the middle then over the rear with no mufflers, Just did this to my cr and sounds amazing. you get a little popping when at idle and run it up to around 4500 but not too loud while driving and sounds throaty at idle. If i can get a video of mine running I will.
Car: '85 Camaro Z28
Car: '85 Camaro Z28
and how bad does it drone at cruising speeds
1 Post
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
I have a 355, Vortec heads ect, running Hedman Hedders 1 5/8 primary to 2.5 collector into a 3" hi flow cat, to a Ravin muffler. I have been told ??? that a 3" single is approximatly the same as having two 2.5 pipes out? I don't think they make Ravin anymore, but I'm really happy with this set up.
Check out my You tube vid
http://www.youtube.com/watch?v=8KkEVNK7DB8
Car: '85 Camaro Z28
you wouldnt happen to know the part number of that muffler would you? twin tips right?
Chuck84TA
07-15-2016 09:05 PM
ambainb
04-25-2016 09:21 PM
