Chrome polish vs. cola myth tested!
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I have taken pictures of my exhaust one was cleaned with cola using aluminum foil the other was cleaned using the leading brand name chrome polish.
The first picture is chrome polish and the second one with cola. As you can see the cola works much better as it removes surface rust and provides a nice shine. The third picture is of my IROC.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Chrome polish vs. cola myth tested!
So you were watching that re-run today too and I tried to remove the haze on my paint with cola but no go...
Can't find anything to cut it, though I can wipe it around with a bare hand.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I have not tried aluminum foil and cola. But I know aluminum foil and white vinegar works wonders, but has a bad smell till you wash it with soap and water.
I have never heard of the vinegar one before but I can see how that would work. I should test to see which works best.
Hotrodboba400
12-10-2019 07:07 PM
sreZ28
10-22-2015 08:21 AM
