new dual setup you may not have seen before
1 Post
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: new dual setup you may not have seen before
Very nice work!! I see you got the IRS done, GOOD JOB! I only with the thread was still there
Im gonna mail you my car so you can do all that to it haha I wish.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
at first i was like "um, wont work on our cars buddy" then i realized who this was...
very nice exhaust setup there.
very clean.
now please post the rest of the pics from your build.
i really want to see how this finished up
very clean.
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Sickest Iroc i've ever seen! How's she handle?
Car: 87 GTA
Nice! Just wish you hadn't deleted all your pics from your IRS install thread. That was tons of great info in there, despite all the haters that posted. Face it.....They were just jealous!
Car: 87 iroc z28
Engine: 89 C4 TPI ,
Transmission: ZF6 speed , 89 C4
Axle/Gears: 89 corvette rear end
Go see (my 87 monster) c4 rear plus a better custom exhaust,and bumper to match.Take it to the next level.. FYI, you will have to change your rear shocks to coilovers,or you will burst them!!
Thats a very good setup. I have been thinking of doing that but was told the TQ arm is in the way. Mind if I ask how you did yours .......is the TQ still there ? factory , modified or aftermarket.
Closeups of how you did your T56 X-member and how the pipe is router around there would be great
I see you got 13 photos but no info on how you did it. did you have someone do the 89 IRS for you?
Car: 87 GTA
You didn't notice the rear end was different? He has a Corvette IRS, so there is no torque arm anymore.
I didnt know the IRS deletes the TQ arm......hmmm....another good reason to go IRS....but looks like a lot of work but 5 stars on cool factor.
So when choosing a IRS what year is recommended ? what yr did you (1meanZ) use ?
Good thread though, I wish he'd left it up, it was an amazing project and I'm mad jealous.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
wow I never realized you got the irs done looks awesome
No idea, but probably not very good. I have a LOT of dial in work to do. I cut 3/4 coil off the stock front springs to lower the front of the car, eventually I'll put weight jacks up front when I can afford it. I am waiting on the parts for my rear sway bar to come in and I'll finish that. It will take me a few auto-x events or a couple track outings to get the car set back up. I may need to change front spring rates, and adjust roll stiffness as well as dial in my shock settings. I doubt I'll be lucky enough for this to be a home run right away.
I have looked high and low and I can't find pix of what you are talking about. I've also sent you 2 PMs of which you've not responded. Can someone else post a link to this car? Also FYI, I thought about doing center exhaust and decided I didn't want to cut up my storage well in the back. My battery is back there and that is where my tool box fits. I decided to go for simple, clean and understated, that is "next level" enough for me. I'd also LOVE an explanation of how I'm going to burst my shocks.... I have the appropriate bump stops in place to keep the shocks safe from bottoming, and since the shocks are longer that the C4 units and allow so much suspension droop that the knuckles hit the leaf spring, I put limit straps on the shocks as well. I'm looking forward to your explanation on this and a link to pix of your car.
1 Post
Thats my opinion anyway.
did some C4 come with TQ arms ?
Rapid Rods:
I finally found pix of your car but they aren't very educational because I can't see how you did anything. How are you mounting your rear sway bar? How wide are your rims in the back? Some other pix of the rear of the car under construction would be great so we can see how you mounted your coil overs, what you did with your fuel tank and wheel tubs, as well as the front of the differential mount.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
is there a thread that explains how to do this corvette rear mod?
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
thats is awesome fab work!!!!!!!!! thats all i got to say
Once the car is drivable and I get my rear sway bar installed I may take some final installed pix and post a few more pix of how the job finished up. There has been a lot of interest in the project and I do appreciate the interest. I just got tired of staying up late posting pictures just to have my butt kicked by a bunch of rude internet bosses.
Car: 87 GTA
The sad part is....Those of us that supported your efforts & looked forward to seeing how it all turned out & never once gave you any grief....Lost all the good info just because of a few losers who couldn't wait to see it finished & ruined it for the majority of readers.
I ask on behalf of the majority of TGO members....Please restore at least some pics & info. Please?
You get the last laugh on all the doubters, because you did it & did it successfully.
its a great looking exhaust system but i'm more interested in the irs.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
ya i got ROH rims to
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Great job 1MeanZ.
Tony.
Tony.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Is this 1MeanZ from Z31Performance as well?
Anyway this setup looks killer. I wish I could feel how it rides.
Car: 1987 Camaro Iroc Z
Engine: 327
Transmission: Soon to be Muncie 22
Is this all pre made pipe? Or did you do the fab it?
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
crotch waffles. Funiest effin thing i've ever heard anyone called. That and a screen waffler (A guy who looks at other players screens while playing video games to get an edge). I am so using this term from now on. Just curious, where did you get the term from?
#44
1 Post
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Wow, 1mean Z what can I say...AWESOME job..Love the garage, and flag too..the IRS is just way too much...I would like to see some more of that...How does it change the way the car performs on the road????? Update please, and who gives a rats a$$ about what anyone else thinks??? I is your car do what you like..I think you did some fabulous work to it...WTG........I only wish my own read end looked that good.lol.
#45
1 Post
Car: 92 Z28
Engine: Boosted LSX
LOOKS great. love the IRS swap also. glad I saved all the pic's form the thread in the past.
Tell all the haters to F.O. Im sure there are 10x the amount of people who like what ya did.
#46
#47
1 Post
Car: 89 RS, 92 Z28
Thanks I will do that...Once again, fine job....
#48
Car: 1986 Z28
Engine: ZZ3
Hey sorry so late on this but I just found this from a different thread. Great fab work. I wish I had the kahonies to do this to mine. Thinking outside the box is what hot rodding is all about. Awesome.
#49
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Not a hater, I love the Twin Traction Beam Ford 4x4 axle design... But for the rear, I would never consider IRS... A live rear axle seems like a generally smarter idea for most purposes and considering how many people here are EFI haters and prefer carbs, this is the last thing I'd expect... (For the record, I do LOVE carbs but EFI has it's points...)
What made you decide to go Independent Rear Suspension? IFS is bad enough... (At least on trucks) But I come from more of a 4x4 truck world so a street car viewpoint is something for me to discover more on I imagine.
#50
If you design a race car, you put in IRS these days. The solid axle is great for drag racing, and it can be good for cornering, but it's never going to be ideal. If NASCAR could run IRS, I bet they would.
