Exhaust cut-out question
Old 01-07-2010 | 08:26 PM
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Ok guys I need help with this. I have hooker long tubes going to a mufflex y pipe to a edelbrock cat back, there is no cat on the exhaust. What I'm trying to figure out, is it worth putting a cut out on my car after the y-pipe? Will it make more power or should I leave it the way it is? Thanks
Old 01-08-2010 | 02:56 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Exhaust cut-out question
it will make more "seat feeling" power, but nothing too big, would be alot louder!
Old 01-08-2010 | 03:33 PM
RU1NER's Avatar
What size exhaust and what type of muffler?
Old 01-13-2010 | 01:32 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if you have the HP. or a moded ENG install 2 cutouts about 10" back from the headers.
the one im doing now
hooker 2210 Headers
into a Y pipe about 8 to 10" into the Y pipe I install cut out's on Ea side then the rest of the way into the Y pipe and then into edelbrock cat back
and RPM muffler. it's 3" tube from headers all the way back to muffler
at the track you can open them up by removing the wing nuts $ plates.
a long time ago when we made the TQ tubes to go onto headers
we would take the 3"tube about 15" long and bolt them the the headers
use a cheap spray paint. on them make a run or 2.. take them off.
you would see how the tubes are discolord.. cut them 1/2 in after the discolor that would give you max TQ $ tune from your header.
most of the time it would be about 8" to 10" long (ball park)
Old 01-13-2010 | 07:53 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Completely different setup but i made 10 HP less on the dyno with my cutouts open a few years ago. I was running longtubes and true duals with no X pipe at the time.
Vintageracer
01-10-2020 06:33 PM
chazman
08-28-2018 04:25 PM
SLNTSCPE
08-22-2015 10:15 PM
redmaroz
08-17-2015 12:40 AM
gta power
08-13-2015 07:15 AM
