Doug's Longtubes and Mufflex Y-pipe
Car: 1988 IROC-Z
Engine: 385 Miniram/Holley HP EFI
Transmission: Probuilt TH-700R4
Axle/Gears: Moser 12bolt 3.55
Does anyone know if the Dougs Longtube headers and the Mufflex Y-pipe bolt together. I am considering getting Doug's over the Hooker 2210's.
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Re: Doug's Longtubes and Mufflex Y-pipe
yes, it willl work. that is my setup all though i modified it a bit more to get more ground clearence and also welded the exhaust vs the clamps because the kept getting loose very easily.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
what about with som headman long tubes. i can get a set cheep but need a y pipe to go with it
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I would also like to know if the mufflex y will work with hedmans.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Brought back from the dead.
Just looking for any more input from those using the Mufflex y. Anyone else have experience with this and the Doug's headers? Opinions?
Car: 1991 CAMARO Z28
Engine: 350 L98
Transmission: 4L60
Axle/Gears: 3.23 (G80,G92)
did you find a y pipe for the headmans??? im in the same situation
88SS6SPEED
11-11-2015 07:05 AM
