Whats the difference between these headers??
Hedman 68470, 68471, and 68481??
I want to a simple true bolt on header and y-pipe setup that will not be a hassle to pass smog in CA.
Re: Whats the difference between these headers??
So I went on the Hedman website and found that only the 68481's are legal for CA...would that be the best setup? what are some comparable to these from other companies?
1 Post
Car: 1990
Axle/Gears: stock
go look at hooker 2055 - they are carb approved and run into a 3 inch y pipe. probably the most common.
dyno don will sell you a set of his custom ones - he is the man.
Car: 1987 Trans Am
Engine: LQ9/L92
Makes life difficult for all and expensive for some
Dyno Don
17
11-02-2015 11:43 PM
hectre13
09-08-2015 03:38 PM
