exhaust rattling after engine swap
Car: 82 camaro unique
Engine: 327 out of a 68 vette
ok so here it is.
i swapped engine after i bought the thing with a cracked block.
was orignal a 305 and i put a 327 out of a 68 vette in it the block has been bored 30 over fit right in there.
but ever since then my exhaust sounds like ****...... any ideas of what to do?
your help would be greatly appreciated
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: exhaust rattling after engine swap
hum... never heard doodoo before lol like is the exhaust itself rattleing like the pipes or just a odd exhaust note?
i think its actually both...........
Make sure everthing is tight and check to see if you need new hangers and rubber for the exhaust.
Car: 91 mustang
Engine: ls1
Axle/Gears: 3.55 8.8
is it rattleling near the engine? if your useing the stock exhaust or headers that use the stock heat riser piece, i had a rattle once and it turned out to be the linkage on the heat riser. removed the linkage, problem was solved.
just a thought.
just a thought.
theshackle
03-05-2017 06:37 PM
