new headers and y pipe - Dyno Don's
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
just got around to installing the new set of Dyno Don's headers, with new gaskets, arp header bolts, a magnaflow cat, etc. worked out good, a few kinks, removed the A.I.R. system cuz it was ghey, and cleaned up a lot of wires .. was a good project.. replaced my edelbrock TES headers which were leaking like crazy too
my younger cousin james helped me, hes in 2 photos, he was a big help, we got the job done!
first are the old cruddy headers, then the installation of the new ones, along with the air system removal, then some photos of the Dyno Don's headers and y pipe
![](http://www2.propichosting.com/Images/4600004239/1.JPG)
![](http://www2.propichosting.com/Images/4600004239/2.JPG)
![](http://www2.propichosting.com/Images/4600004239/3.JPG)
![](http://www2.propichosting.com/Images/4600004239/4.JPG)
![](http://www2.propichosting.com/Images/4600004239/5.JPG)
the car is road ready now!..
Car: 1987 IROC-Z
Re: new headers and y pipe - Dyno Don's
the car is road ready now!.. the 2nd to last photo is of my brother heading off to his training weekend in philly with the USMC, his 87 GTA is for sale/trade for a street bike, but hes keeping his 97
Car: 1985 Trans Am
Engine: 360
How much did the Dyno Don headers cost you? I was thinking about getting some in the next couple of months. I'm going to need headers to put a dipstick on the 350 I just put in. Are the headers made for a y-pipe? I have a problem because my y-pipe hits the bottom of the oil pan on the 350 and can't connect to the manifold, so I'll need to run two straight pipes from the headers.
Car: 1987 IROC-Z
wel, dyno don will be better to help you but the setup i ordered from him was 2 headers, a y pipe, a connector pipe, and a bent pipe.... for around $700.00 and its way worth it, easy spark plug access and clean look
Car: 1987 IROC-Z
i did but it was a seat of the pants feel of a gain.... still a bit of a gain, cuz the edelbrock headers got crunched at the collector .. i can show u pics if neede, bvut the stamped edlebrock got leaky in the gaskets after 6 yrs... 6 hard years
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Did the O2 sensor wire reach the connection or did you have to increase the length?
Also, did the dip stick bolt in the original location on the head?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
What kind of cat converter is that? Is it 3" in and out? It's tiny!
Nice job all around.
TA
TA
Car: 1987 IROC-Z
the o2 sensor wire was plenty long enough, i jsut zip tied it taunt to keep it from flopping around too
the cat is a 3" in and out magnaflow piece, on jegs.com for like $79, its a high flow cat, also designed to be compact for good ground clearance etc.. i needed a new one (8yrs on the old one) and since i removed the AIR system, i needed a cat without the AIR pipe coming from it
right now the dip stick is still an issue, im trying to figure out a way to make a bracket to keep it tight, .. havent configured it yet...
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
how do you get rid of the A.I.R system and do you have to reprogram the ecm for that
Car: 1987 IROC-Z
there are lots of pics of the car on my website ,,,,listed below
removing the a.i.r. system is easy, its all just tubes and bolts and a few hoses, tehr are 2 wires, u jsut unplug them from under the black plastic box by the air pump, wrap em up and hide em someplace, and pull off anythign that has to do with the air system... there should be no isses with the ecm or anything, i havent ran into any.. correct me if im wrong on this guys.. also i thinkt her is a big post on removing air system on this board... search for it, i will do likewise later
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The plug access between the Edelbrocks vs Don's looks night and day different.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
what you do with those eldebrocks im looking for a set myself, Don built me a special y pipe for my eldelbrock tes with dual cats but my collectors are rusted so i need a set of tes pm me if you still have them
Car: 1987 IROC-Z
well, my cousin wanted them for his 88 camaro, but ill have to check if he really wants them or not.... i have them in the basement now
Car: 1991 Camaro 1LE
Engine: 350 L-98
Axle/Gears: Dana 44 10 bolt 3.73 gears
HI Irocman15
I just finished bolting my Dyno dons headers onto my car also but have yet to hook up the y-pipe. Did you put donut gaskets between the headers and the y-pipe???? ANy problem with leaks between the y-pipe and headers??? Any help would be appreciated thanks Eric
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I believe they're ball and socket, needing no gasket.
Car: 1987 IROC-Z
HI Irocman15
nope, i P.M.'ed don the same question, and he told me there are no gaskets needed. I went out and bought some grade 8 stainless steel bolts and spread some never-seeze on them also, and tightened everything up.. then i went back a week later and re-tightened everything, i have had no leaks, and as far as i can tell, they flow great.
any other questions, feel free to ask!
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
that converter is a new style Magnaflow "Spun" converter. I recently got one for my car in conjunction with my dyno dons headers and y pipe.
I got mine for like $72 shipped off of ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...3785&viewitem=
Car: camaro iroc-z
Engine: 383
Axle/Gears: 411's
cheers mate.
Car: camaro iroc-z
Engine: 383
Axle/Gears: 411's
that y pipe might be a problem on mine since im runnig a oilpan with kickouts. dam this might be a problem.
LT1Formula
20
11-14-2015 12:02 AM
