Short headers
Car: Firebird
Transmission: Manual
Short headers
Hi all,
Has anyone ever used headers like this one? I can get a cheap pair and was wondering if they are feasible?
Any help would be gratefully received
Car: Firebird
Re: Short headers
I've got a 305 '86 Firebird manual. They are made for the SBC but its just whether they are any good. I'm going to be fabricating my own system from the headers back. Just thought these might be a good start?
Cheers
Cheers
Car: 1984 Pontiac Trans Am
Axle/Gears: stock, for now
Re: Short headers
That style does not look to fit. They look more like a truck or street rod header where clearance is not an issue. For something that will fit your car for less than $100 go to summitracing.com and search for this part number SUM-G9005
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Short headers
Those won't fit... the collector on those headers exits right ontop of the crossmember under the oil pan. You'll never get it hooked up to an exhaust pipe, even a custom fabricated/bent one. Those are meant for hot rod and engine swap applications, and also fit some years of Corvette. Will not work in a Camaro/Firebird.
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: Short headers
those look like block huggers. i couldnt tell you how many times i have seen that block huggers will not work on our cars. you can get hooker2460's for like $150 since you are customizing the rest of the way back i think they might work for you. but not the ones you are looking at.
Car: 1991 Camaro RS
Engine: 350 SBC
Re: Short headers
I used the summit SUM-G9005 and they bolted right up. just make sure you use good wire looms and not plastic cause the passenger side melts them I discovered
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: Short headers
those will not fit with out major fab work..those are block huggers for a v-6 to v-8 swap for a s-10 truck..won't have the clearance you need to make the bend because of the k-member
Car: 1991 Camaro RS
Engine: 350 SBC
Re: Short headers
Well they fit my 91 that I swapped the v6 for a 350 v8 and I had to get the Dynomax performance exhaust dual kit and mufflers to install since no one would do the exhaust at a shop.
1 Post
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Short headers
taz -- read post #7 carefully.
The 2460's are a drop-in fit. Biggest problem will be clearance/access
for 3 bolts, where the tube bends to that direction. (My solution was
a judicious use of heat, & channel locks, to get a bit more clearance.
Some prefer a BFH. )
Car: 1991 Camaro RS
Engine: 350 SBC
Re: Short headers
Sorry for any confusion people. I used the summit 9005 headers and did have to do some modifacations to the exhaust kit I ended up using and will post some pics when I can.
Car: 1991 Camaro RS
Engine: 350 SBC
Re: Short headers
Im sorry been busy but I do have some pics of the exhaust work I did and will do sound clip soon. Sorry for any confusion earlier
Re: Short headers
hey taz that looks good! i have to get more pics up of mine sometime or another. i need to take my headers back off and open the collector up some more. i've got hooker 2055's and they have a ball and socket fitting. leaves a carbon ring on the ball part. gonna cut it away to allow for more air flow.
