80 series flowmaster
Car: 1991 Trans Am
Engine: sb chevy's.
how does the flowmaster sound on a 305? does it help much if you redo the whole piping to 3 inch and make it true duals. What about hp. gains? Does anyone have video clips of their thirdgen with a 80's series.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: 80 series flowmaster
I'd stay away from flowmaster. The design just doesn't work with an F-body designed system. I can't tell you how many times I've seen swaps from Flows to something else and there's always a gain. Look at the Hooker catback systems. They work awesome, sound sweet, and are priced decent.
If your 305 isn't heavily modded, go with what you think sounds the best. It's not going to make a difference HP wise if you go with a Flowmaster or Aerochamber. Pick which system sounds the best to you, and be happy.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
I had 80 series on my car and like they said no hp gain from it. but it sound sweet. I put my muffler where the cat goes and ran the exhaust out the side right infront of the rear wheels. Looked and sounded great. But no hp gain.
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
I have a flowmaster 80 on my 305 Camaro. It is a single 3" cat back, dual 3" outs on the muffler. Y-pipe is stock and I am running a standard catalytic converter.
It has a nice sound to it. Nice low tone, fairly quiet at idle. Compared to my dad's Camaro which has a 350 (low compression truck motor w/tpi on top), mine is only a little bit quieter. His has the same setup except it has 2.5" tips.
On another note, when I first bought mine, it had no catalytic. And, it sounded more aggressive than it does now. Definitely a noticeable difference in sound when we brought it home after getting the cat installed.
Here's a link to the sticky with a bunch of sound clips.
Hotrodboba400
12-10-2019 07:07 PM
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
