What makes the exhaust note "unique"
Car: 86 Firebird
I know that's a very broad question, but I specifically want to know what makes a Mustang exhaust note so melodic, while most sbc's sound more raspy.
I'm not really a fan of Mustangs, but everytime I hear one with an aftermarket exhaust, the sound is music to my ears.
I'm sure my Firebird will never sound like a Mustang, and I wouldn't really want it to anyway, but what makes the Mustang sound like that?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: What makes the exhaust note "unique"
yea, mustangs have a dual exhaust setup, so it will sound different that a single setup.
My original answer was going to be "the size of the tip and what color LED's are in it"
Car: 86 Firebird
I know the pipe configuration makes adifference, but even with a true dual exhaust, the sbc just sounds different. I think it must be something about overlap, or exhaust port configuration....or something.
Anyone else have any ideas?
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
They came with factory headers and true dual exhaust with a h-pipe crossover. :/ Wish GM did stuff like that, at least on the GTA's, Formulas, and IROC's.
Car: 86 Firebird
If they do, that seems like it would change the exhaust note. Can't you do that to a chevy, too? A special distributor or something?
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
It's the firing order that makes them sound distinct.
Small Block Ford: 1-3-7-2-6-5-4-8
Small Block Chevy: 1-8-4-3-6-5-7-2
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
When you say mustang I assume you mean the 5.0's right? Well with the limited knowledge I have of them I can say that yes they do generally have a traditional dual exhaust, most of which are H-pipe from the factory. They also employ a different firing order, which there was a HO and a non-HO order. I believe they also have a shorter stroke than a Chevrolet 5 liter, all which might contribute to the smoother exhaust note your hearing.
Max,
EDIT: Just read the above, that kinda answered it. To the other question, I believe they have a 4/7 swap cam for the SBC. I read something about it giving less crankshaft deflection with notable gains in higher HP engines.
Max,
Car: '83 Camaro Berli | '86 T/A WS6
Engine: 5.7L | 5.0L
Transmission: TH-700R4 | TH-700R4
Axle/Gears: 3.08 Drum | 2.73 Disc
idle.
haha
Disregard this post.
haha
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The two main factors are firing order and valve timing. Thats why LSx's have that weird sound... they have a unique firing order from almost everything else. Combustion chamber design plays into it too, but not as much as FO and valve timing does. The LT1 has all 3 doing for it, and thats why they sound so awesome.
Car: 86 Firebird
I think the firing order was the key I was looking for. When doing a 4/7 swap cam, do you just switch the wires on the distributor? That sound like it might be a good idea...
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
...............................That's what he said
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Just to add to everything else, induction is what really does it to me.
A fuel injected car always sounds domesticated to me. You can "louden" a fuel injected car, but it just sounds like a tame vehicle with a loud-speaker.
A carbed car (i'm not even thinking about bigger cams here yet), will always have a nicer growl to it. Even basic '80s chev trucks (small cam), will sounds nice, vs a cammed up FI mustang for example (1997 car year for example).
But a cammed up small block chev with a quadrajet? Oh boy, that sounds beautiful. A Q-jet's secondaries cracking open sounds pretty intimidating
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
ford firing order is only "different" because Ford counts the cylinders in a different order.... they may have a 4-7 swap. but so do the ls1's
Engine: 3.1L V6
Yep, they have a 4-7 swap as well as a 2-3 swap compared to a gen I sbc. I mentioned that in post #14.
Car: 1983 trans am
to better illustrate my above post here is a crappy paint illustration...(sorry its late and ive had a few drinks)
gm firing order 18436572
ford 18736542
ford 18736542
you must have had a bunch of drinks cause neither one of those is even close to right!
gm:
8 7
6 5
4 3
2 1
ford:
8 4
7 3
6 2
5 1
Car: 85 Camaro IROC
Engine: 5.7 TPI
Axle/Gears: open rear, 3.42 gears
gm:
8 7
6 5
4 3
2 1
ford:
8 4
7 3
6 3
5 1
gm:
8 7
6 5
4 3
2 1
ford:
8 4
7 3
6 3
5 1
what you meant to say was
8 4
7 3
6 2
5 1
Car: 1983 trans am
actually my diagrams are right and my ford firing order wrong. #1 is on the opposite side of GM, gauranteed.... i am a ford technician(definetly not braggin just stating a fact).
15426378 is for the non h.o. 5.0 and 13726548 is the H.O. firing order(different cams)
while the gm order on gen I/II small blocks is 18436572.... gen III/IV hav a 4-7swap
Car: 1983 trans am
haha well we are both wrong then... my GM diagram is wrong. 1357 drivers side and 2468 pass. side
oh well drunk posting FTL
Car: 85 Camaro IROC
Engine: 5.7 TPI
im still not getting this though...
the firing order in a typical sbc is 1-8-4-3-5-6-7-2, which gives a definite pattern since the right bank is 1-3-5-7 and the left bank is 2-4-6-8.
however the ford order than you are posting makes no sense.
the engine would literally vibrate its self apart.
the banks are 1-2-3-4 and 5-6-7-8 respectively...
im confused
im confused
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
im confused
im confused
Ford 1-4 is on the right(passenger) 5-8 on the left. It been posted before but it should look like this.
GM
8[ ]7
6[ ]5
4[ ]3
2[ ]1
ford
4[ ]8
3[ ]7
2[ ]6
1[ ]5
GM fireing order 18436572 Ford either 15426378 or 13726548
Ford 15426378 is identicle to GM 18436572. 13726548 looks to be both a 4-7 and 2-3 swap(in GM) if I am looking right.
transaero
08-31-2015 01:14 AM
