header fitment problems
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Camaro RS 25th aniversary editio
Engine: 305 tbi
Transmission: auto
I put a 400sb in my 92rs and im running hedman shorties. The problem is that the collector flange is up against the frame rail and wont let my mini starter bolt up. The person that had the car before me apparently hit a curb with the passenger side front tire. I had to replace the spindle. Is it possible that the frame rail got pushed in that far or is there something wrong with my headers?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: header fitment problems
TA
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it's very possible you'r a little tweaked , frame wise . but how about motor & tranny mounts ??? old ones can sag/droop and cause clearence problems . oh well , good luck .
Engine: 305 tbi
Transmission: auto
Im going to haul it to the frame shop early next week, so we will see. I went ahead and got all new tie rods, center link, and idler arm. Going to have them replace all of it while they got it. If that doesn't work then we will try new motor mounts.
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
I just dropped a 383 in my 91 Z28 and I too am running Headman Header's Shorties with AIR provisions. My Headers fit BARELY and only after recentering the powertrain with new mounts... (no wrecks)
I have a problem that the Y-pipe that came with my Headmans doesn't fit. The driver's side collector adapater (the slip fit one) isn't long enough. The pipe clears the oil pan fine but the angle and length to bring the collector and adapter to meet it are ALL wrong... I love the headers otherwise... just a little PO'ed that the Y pipe still needs Fab.
Car: 87 TA
Axle/Gears: LSD
Got the same issues with my Hedman headers, are these new stock or old as there seems to be a few problems with the newer versions. The Hedmans I just took off were a really good fit however.
I'll be trying the replacement engine mount option too as the banging around is driving me nuts.
Street Lethal
04-30-2019 12:14 PM
hectre13
09-08-2015 03:38 PM
kah992
08-19-2015 02:55 PM
