2.25 OR 2.5 Pipe
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
2.25 OR 2.5 Pipe
Ok new engine making 360/370. 650cfm carb, hedman elite headers. Will 2.25 dual system work good?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 2.25 OR 2.5 Pipe
2.25" dual flows about the same as a 3" single, so yes it should work fairly well up to around 370-400hp.
Car: 1968 chevelle
there is no exact horsepower level. you need to be more specific with the engine. mainly cubic inch, camshaft specs, head flow numbers, runner size, etc. id put a 2.5 inch on and be done, depending on the cubic inch. if it is a 383+ i would say 3 inch because then u have room for more improvement without choking the motor and having to pay for exhaust twice.
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
350 CID, 76cc heads with 2.02"Int/1.600,Hydraulic flat tappet cam with .480" valve lift, performer RPM Intake, 9.1 Comp. Nothing special.
Car: 1968 chevelle
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Also keep in mind if this is a daily driven car, dual exhaust systems run under a thirdgen lose ALOT of ground clearance. With your "nothing special" 350 I think you'd be better off with a good 3" cat back system. It will save you alot of headaches. Just my .02c
Car: 1987 Z28
Engine: LG4
I am running a 3" catback and love the fitment and ground clearance. From what ive heard my 327 will no be choked up from the setup
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
X3. 3 inch will be the way to go. Plus the 3" single pipe gives a deeper tone than 2.25"
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
would i have to get a custom y-pipe for my hedman elite shorties, (ball and socket flange)?
heres the link--http://store.summitracing.com/partde...5&autoview=sku
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
yea but thats a 2 1/2 single, if i wanted to go with a 3" Y to a 3" intermediate pipe, does anyone make one of those? because it just doesn't make sense to run a single 2 1/2 or run an expander at the end of the Y to make it a 3". Or at least thats what i think? idk lol
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
LT1Formula
10-08-2015 08:34 PM
