flamethrower coil HELP
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
i just installed an exhaust flamethrower on my car the problem is im suposed to connect a wire to the negative on the ingition coil and there are 4 wires running to it two are pink and two are white, which one does it go to?
Car: 87 GTA
Re: flamethrower coil HELP
Ask the company that made it. We aren't going to know which of those wires does what, unless you get lucky & somebody here has the SAME unit. And not too many people here have flamethrower tips.
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
FYI, if you are insured and the car catches fire do to your flame kit, you will not receive any $$$. My friends 88 mustang gt caught fire with his fame thrower kit. The only damage was to his rear ground effects. Keep (2)fire extinguisher in you car.
RedLeader289
05-28-2019 01:47 PM
school boy
10-22-2015 11:47 AM
92rsvortec350
19
10-09-2015 09:39 AM
