All aboard the Orr89RocZ bandwagon!
I know he doesn't have his old exhaust setup anymore, but he inspired me-lol
Yes, I polished my cat back (what a loser, hehe). Yes, I realize the muffler is crooked, I need to make a custom hanger on the driver side. Once I'm done, I'll try and get some good sound clips.
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: All aboard the Orr89RocZ bandwagon!
Those dimples are the chambers. The flow tube(louvered baffle) is not effected. Best of all there is no packing to blow out of it either.
I haven't been able to drive it yet, but I was actually able to slip the muffler on with the car running. It cleans up the sound. Loud, but a good loud with a tone. It doesn't sound like a pickup with no muffler thank god.
I drove around with an open Y pipe for 3 weeks, I liked it, but it was missing a "tone". It was just plain loud.
haha glad to see you going with taht setup. you should like it. I liked mine, but it was in the I pipe so i could retain dual outlets
Last person i recommended that muffler to also liked it. Most cars that have those tubes sound pretty good
I got a quick little sound clip: http://joenowicki.googlepages.com/MOV03751.mpg
I was thinking about dual outs, but I can get that muffler to tuck nice and high. No one will be able to see it. My 80 series had stock turns downs on it, couldn't see them anyway.
i pipe you lose alittle clearance but its much better than my current 4inch design it hits on most things
i'd do a chambered tube again if they had a 4inch inlet model.
Yours sounds pretty good so far, i bet it sounds better if you stand behind it the camera will pick up the sound better
Car: '92 RS
Engine: 357ci
i cant find any data for most mufflers anyway. Its like they rate them on sound and not flow. its like they think exhaust isnt important. I dont see intake manifold flow numbers that often either! two big factors in motor building and they dont give you that information
Car: '92 RS
Engine: 357ci
Yeah the only mfg i've seen put up REAL flow numbers is PYPES. Even then its not on all sizes or all muffs.
Dynomax does and Magnaflow does on some products. If you have a straight through pipe with preferations such as on the DynoMax or Magnaflow you can probably figure what it is going to flow by the pipe diameter. On the above chambered muffler it looks like it has dimples that stickout out into the exhaust flow. That was the reason for the question.
oh it does, and it will distrupt airflow but that is what gives it the distinct chambered tube sound. Sorta like the old Z/28 cars back in 69. I do believe they had the same mufflers
They will flow a good bit but how much i dont know. Less than a straight peice of pipe i'm sure but better than most flowmasters i'm sure
This is as close as I've found to a list of muffler cfm ratings.
I lifted this page from another online forum.
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
Remember.
2.2 cfm of muffler flow per horsepower for zero loss due to backpressure.
All tests @ 15” wc
Remember.
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
that was me! ya man thats a great system. only reason i dont have it anymore is my pipes rusted at the Y and didnt feel like paying to fabricate a whole new system and then i gotta really good deal on a magnaflow catback. but ya ur gonna LOVE that muffler
Small update. Found a universal hanger at autozone. Grinded some of it off, heated it, bent it, tapped a hole, and welded it to the tail pipe. Now the muffler sits nice and straight.
Sorry, my sister took her camera with her on vacation. No sounds clips until she comes back. But driving it around, it's not obnoxious at all. No louder than the flowmaster (80 series). At least from what I hear inside the car.
Take it over 3000 RPM, and it gets a real nice throaty tone. Couldn't be happier. Over 3k it is louder than the flowmaster by quite a bit.
This a fairly decent listing.
Still looking for sound bites though.
http://www.exhaustsoundclips.com/cfm.pdf
Car: 2011 6.2 Silverado, 88/85 camaro
Have that muffler in the I pipe section, 26/20 3", it sounds very mean, and well, yea getting on the throttle a bit really wakes it up. After letting off there is no crackling sound, just a great pure exhaust tone.
