Camaro headers on Corvette heads?
Car: '90 Camaro RS
Engine: L03 TBI
Transmission: TH700R4
Axle/Gears: 3.42 open diff
Is it possible? Can I bolt on L98 Camaro headers on L98 Corvette heads? What heads and headers should I use on my '90 Camaro with a Corvette block?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Camaro headers on Corvette heads?
Ports are in the same location - they will fit.
Car: '90 Camaro RS
Engine: L03 TBI
Rich92RS, I see you have the aluminum Corvette heads on your IROC. Which headers do you use, if you dont have the stock exhaust manifolds? Are your heads exhaust ports D-shaped?
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
I've got the D shaped ports, but I'm still using the stock exhaust manifolds.
