2210 + Spohn Torque arm inside
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Mounted 2210' on my GTA together with a Spohn torque arm.
- Made a new crossmember to lift the Y-pipe as high as possible.
Pipes are 3" and then 3.5"
( No time is spent on the looks, just want it out on the roads again )
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: 2210 + Spohn Torque arm inside
one more................
the "red ring" is where I will place one WBO2 if you wonder
Car: '82 Z28
What kind of clearance do you have now where the exhaust passes under the crossmember? I only have 3 inches, well probably 3 1/2 now since it's been over a few speed bumps lol.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Looks good. I wish I could tuck my exhaust up like that. Do you have any pictures of the 90 degree welded parts (close up or off the car)?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Do you plan on any strip action? If so, what size stall do you have? I was wondering if the TQ arm mount will take abuse, doesnt look like it will flex.
i'm sure that new crossmember is strong but it sure doesnt look like it. doesnt seem like much material there to hold new pieces together.
I would puta triangle gusset support up there
I want to do the same thing to my crossmember tho as i just dropped my motor in and looking at how the 2210's exit, i'd have to go slightly under the spohn member and its low...
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I think I'll need a 4L80E and strange rear also soon....
Stall is a street friendly ACT 9.5" 2400rpm
TQ arm mount is solid as it is on Spohns org crossmember.
I hear you, Pipes under the spohn X-member will make tha car extremly low. The other way around it is to cut or rework the frame. I was thinking of doing it but since I didnt have the time to do it now I did it this way instead, when I put a 4L80E trans in I need to do a new crossmamber and y-pipe again and maybe then I'll rework the frame....
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Mine doesnt have he most ground clearance but the cutouts didnt help that ither.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Nice fab work. Any way we could see some pics of the crossmember out of the car when you do your tranny swap?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The headmans sont clear a T5, i had to hack mine, good thing o just got some hooker super comps.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
BOTTLEDZ28 nice work. Kinda looks like mine.
The T-56 isnt as wide as the TH700 so you will have more ground clearence than with a TH700.
Will post some more pictures next week.
/N.
New2Chevy
09-28-2015 12:35 AM
