pics of my dougs 1 3/4 LTs and X-pipe true duals!!
Old 03-25-2008, 10:40 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
here are some pics....the site only limits me to three pictures.
Attached Thumbnails pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0699.jpg   pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0701.jpg   pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0702.jpg
Old 03-25-2008, 10:43 PM
Re: pics of my dougs 1 3/4 LTs and X-pipe true duals!!
more pics...
Attached Thumbnails pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0703.jpg   pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0704.jpg   pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0705.jpg
Old 03-25-2008, 10:46 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
looks pretty good i think.
i be more careful on speedbumps.
your oilpan looks pretty scraped up. the headers look like they sit lower so i watch out for bumps and stuff.
Old 03-25-2008, 10:49 PM
guess what, more pics.
Attached Thumbnails pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0709.jpg   pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0710.jpg
Old 03-25-2008, 10:51 PM
joshh44's Avatar
Engine: engineless
where did you get thos seats?! i like em!
and i also like your doorpannels!
im looking in getting some racing seats. where did you get yours and how much did they cost?
i really like them.
just a couple more
Old 03-25-2008, 10:59 PM
the very last two....
Attached Thumbnails pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0711.jpg   pics of my dougs 1 3/4 LTs and X-pipe true duals!!-hpim0712.jpg
Old 03-25-2008, 11:11 PM
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
exhaust looks pretty good i think i'm gonna do something very very similar I have to see how much clearance i will have tho. Those longtubes look to hang as low as hookers and i was hoping to tuck it up abit more than what it looks, but its hard to say just by looking at pics
how is your ground clearance and is your car lowered at all?
Old 03-25-2008, 11:21 PM
the car is lowered courtesy of hotchkis springs that advertise a 1" drop but it looks more like 1.5" to me and everybody else who always say the stance is killer. Ground clearance is suprisingly good, just a TINY BIT less than the edelbrock shorty y-pipe deal I had before and of course these mufflers hang a little lower than the flowmaster I had in the stock location too. It'll take a pretty nasty speed bump to rub though.
Old 03-25-2008, 11:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
nice! my car is lowered about the same and i need headers. Seems to me i'll be getting dougs as well and running some sort of true dual exhaust. I now need to either cut the subframes or crossmember to fit them better. I'm thinkin spohn crossmember mods will be necessary to try first before i cut the cars frame
Old 03-26-2008, 11:32 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that looks AMAZING! i'm thinking i'm gonna do a k-member first, but those dougs headers are definitely on the agenda over the next year.
Old 03-26-2008, 02:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you dont need any of that,your fast enough!
Old 03-26-2008, 04:07 PM
Drone358's Avatar
Hey man.... that looks good, id like to do true dual and then come out separate ways and go in front of the tire... with a thin and long tip...kinda like nascar does there underbody with the exhaust, u know like the ford lightnings did the exhaust on one side.. id like to do both sides!
Old 03-26-2008, 05:44 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
first of all, very nice exhaust!
haha second im thinking of doing the same thing with hedman lts, just wondering is that mandrel bent or crush bent? from the pics it looks crush, and what size pipe did you use? did you do it all yourself? or did you have a shop do it? and if you did, what did all of it run you? also what kinda mufflers are those?
Old 03-26-2008, 05:55 PM
put it on the dyno today(free hookup ) the exhaust made a whopping 21.7 whp more over the 1 5/8 edelbrock shorty y-pipe, full 3" no cat to a flowmaster crossflow muffler setup I had before and sound a LOT better doing it too!!! that X-pipe with the magnaflows=VERY deep and throaty. So on motor it made 358.4 whp@ 6400rpms(could probably get more if i screwed with the carb a little more) and 367rwtq@ 4500rpms. On a 125 shot it made 476whp@ and 485.6rwtq but I know I can get more because the air/fuel ratio was reading 10:8 at the top during the nitrous pulls so going down to the local speed shop tomorrow to pick up a jet assortment kit and shoot for around 12:0-12:4 air/fuel ratio and that "should" up the numbers a little i think. I'll then head back up to the dyno and see what it does. All the runs were on shell V-power 91 octane, 33* timing on the bottle, 38* on the motor.
Old 03-26-2008, 06:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
wow thats a good gain!
Old 03-26-2008, 06:05 PM
chevyrules, my friend at exhaust pros bended and welded up the tubes(not mandrel bent) for me and the mufflers are magnaflow straight throughs...could tell you the part# if i knew what i did with my warranty card. The shop is also a magnflow dealer and he suggested those mufflers for a 100% unrestricted flow, extra clearance and the bad a$$ deep bassy rumble especially with the 236/248 duration cam...it has a lope to die for!!
P.S- 2.5" pipes
Old 03-26-2008, 06:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
what is your motor setup if you dont mind me asking
Old 03-26-2008, 06:40 PM
mw66nova's Avatar
Engine: 7.0L
haha, when is fast enough...enough?
Old 03-26-2008, 07:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
when your radial tire king and well into the 8's
Old 03-26-2008, 09:00 PM
Andy316's Avatar
Man, your car is awsome. Its like you crawled into my head and stole the ideas I had for my car and did them before I could. Everything headers, exhaust, seats, cage, dash cluster. Your friend did a real nice job on the pipes. I hope mine comes out as good as that.
Old 03-26-2008, 09:21 PM
Car: 85 camaro
Axle/Gears: 342
so did he run into any problems running both pipes over the axle in that spot? anything that anyone else should watch for if they attempt this?
Old 03-26-2008, 11:03 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Well i just ordered my dougs! Summit was backordered till mid april so i bought them through Jegs. $549 Shipped.
Thats a beautiful looking setup. I thought of doing something similar, but i think im just going to exit before the rear tires. Haven't decided completely i got a really good exhaust guy who ill just leave the car with him and let him do his thing.
Ive seen your setup done on a few 4th gens, thats gotta hang pretty low if you are right under the driveshaft. Do you have any shots from the side at ground level?
21rwhp gain with that exhaust setup is amazing! Bet you were happy to see that. Thanks for sharing the pics!
Old 03-27-2008, 01:41 PM
Drone358's Avatar
yea i would sure like to see some pics of it on the ground.. jus to see the ground clearance cause u said its already dropped an inch n half and u still have good clearance... i have the 2210 Hookers.. i wonder if the clearance is the same??
Old 03-27-2008, 02:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it should be since the two headers are nearly identical and designed by the same person i believe.
Old 03-27-2008, 07:33 PM
chevyrule, there was no issues to get the tubes over the axle, just bend them right I guess. Orr89RocZ my combo is as follows:
forged and arp studded 10:2:1 355ci
edelbrock performer rpm alum. heads 2.02/1.60(angle plug), rpm air-gap manifold, 750 holley DP, comp hyd. roller 236/248 dur @ .050, .520/.540 lift @ .050, scorpion roller rockers, built 700r-4 with edgeracing 9.5" 3200 stall, built 10bolt(moser 28spline axels, c-clip eliminators, torsen posi, 3.73s, ls1 driveshaft....), all the other suspension pieces except for a cross-member mounted adj. TA(getting one before the season starts). Anything else just ask.
Old 03-27-2008, 07:46 PM
mw66nova's Avatar
Engine: 7.0L
hey leeperryracing, do you think that my little 305 (that runs 12.3/4's) would benefit from a 1 3/4" primary? i'm going through the traps right now at 6400rpms...
Old 03-27-2008, 07:52 PM
Drone358's Avatar
Hey leeper.. is there any way you could get a sound clip of ur setup.. i seem to have the same setup with heads, carb, intake, and cam... really would like to know the comp. ratio and the sound of it cause i should be makin around 500hp
Old 03-27-2008, 08:04 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
WOW!!! they did a great job!! I want my exhaust exactly like yours!! thats a killer set up man
Old 03-27-2008, 08:11 PM
Matt, to be honest I think 1 5/8 primaries is plenty for that 305, 1 3/4 would actually cost you some low to mid-range torque and you'd probably have to wind it higher than 6400rpms to make the same numbers.
Drone358, I don't even know where to begin to get a sound clip man
Last edited by leeperryracing; 03-27-2008 at 08:12 PM. Reason: Automerged Doublepost
Old 03-27-2008, 09:06 PM
mw66nova's Avatar
Engine: 7.0L
i thought about that...but then i keep thinking of all the stock elminator guys that are running the hookers on their 305's...but they spin them a little harder...but i'm planning a cam swap that will allow for power up to ~7k i think.
Old 03-28-2008, 02:10 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Nice job. I have to wonder why you didn't take any pictures showing clearance (or lack of) with the car on the ground, maybe with a soda can for perspective. Those headers look to hang as low as Hookers, if not lower. Could you post a couple of pics?
Old 03-28-2008, 03:05 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Nice, clean look. Good job. Just curious, what are the bolts through the floor in 2 pics holding down?
Old 03-28-2008, 03:39 PM
Drone358's Avatar
ahh.. maybe a video or somethin.. im jus dyin to here my engine and was hoping you had something lol.. nice setup, what around hp are u running you think?
Old 03-29-2008, 12:39 PM
Stevo's Avatar
Got my Doug's today! Here are some pics, they look nice except i'm wondering about the slip fit joint on the #8 primary. Have you had any trouble with it leaking or once its installed the heat seals the pips up?
Other then that i can't wait to get these installed this week!
Some pics:
Old 03-29-2008, 01:13 PM
the seats
Old 03-29-2008, 01:21 PM
Stevo, I was pretty skeptical about that slip tube too but all you have to do is "wedge" it in properly to make sure there is no free movement of the tube and it'll be good. Put the header on first and then fit that tube in as you'll have to line up the flange on the head if that makes sense.
P.S- hope you got an LT1 starter handy(any parts store will have it,got mine from autozone).
Old 03-29-2008, 01:24 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
the pics are great but i wanna no how the mother****er sounds!!!
Old 03-29-2008, 01:57 PM
I am going to work on getting a sound clip....
Old 03-29-2008, 05:56 PM
Stevo's Avatar
Yup i already have a ministarter, as well as a tubular k-member and virtually nothing in my way, so it should be a clean install. I also run a 5 speed though so i hope the slave cylinder doesn't interfere.
Old 03-29-2008, 07:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
good luck with that, looks like a nice set of headers. I cant wait to order mine. I just missed out on a deal for some hooker 2210's tho its a shame he sold them to someone else cuz i could realllly use them now
Old 03-29-2008, 11:16 PM
  #42
Stevo's Avatar
Ya, i know lol i was pissed to see them sold at the price too. I would have bought those in a heartbeat if i didn't already get these. But i'm happy with these, i just hope the fitment is decent.
Old 03-29-2008, 11:27 PM
  #43
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
dude, i got the cage, the same seats, and the same g-force racing harnesses.. wow.. nice exhaust though.. sure beats mine..
Old 03-29-2008, 11:43 PM
  #44
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
to the OP how much did that whole set up run ya?
Old 03-30-2008, 09:11 PM
  #45
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
That looks amazing, i wish i could have done something like that with my car. Nice power gains too.
Old 03-31-2008, 04:49 PM
  #46
Stevo's Avatar
I got my headers in, by far the best fitting headers i've ever seen or used. It does help that i have no ac/heat/ministarter/tubular k-member. But 100% bolted in, did not have to modify anything, didn't even scratch the headers up. They clear the slave cylinder in the bellhousing by at least a 1/4-1/2". I run angled plug heads, and the passenger is fine with normal length plugs and it looks like the driver side bank should be fine also, havent put the plug wires over them yet but the plugs were easy to screw in and out. I am running new polyurethane mounts, and i didn't even have to bring the motor off of the mounts. I slid both headers in from the bottom. Now for ground clearance, i have a 7 quart deep pan and they sit about flush with the pan. I would not say they hang that low, not really visible from the side of the car. I will make a new thread tomorrow and post detailed pictures once i get a camera.
Old 03-31-2008, 05:23 PM
  #47
alright Stevo!!! thats what i'm talking 'bout
Old 03-31-2008, 07:07 PM
  #48
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
stevo, what bellhousing are you running? stock or lakewood?
Im looking at the same headers as well. once the other projects are done.
Old 03-31-2008, 07:12 PM
  #49
Stevo's Avatar
Stock bellhousing with the adapter plate for the tremec. Ill get some pics up tomorrow.
Old 03-31-2008, 07:16 PM
  #50
6.LIROC-Z's Avatar
Engine: 6.0L LSX Carbed
Axle/Gears: 3.73 Strange 12 bolt
So what does this beast run ?????
Quick Reply: pics of my dougs 1 3/4 LTs and X-pipe true duals!!
