EXTRA CAPACITY OILPAN W/ HOKKER 2210's
Car: 1991 Camaro DZ302
Engine: destroked 350(DZ 302)
Transmission: turbo 350
JUST WONDERING WHAT KIND OF OILPAN I CAN RUN THAT HAS EXTRA CAPACITY, I AM RUNNING HOOKER 2210's WITH A SMALL STARTER AND SOLID MOTOR MOUNTS.
Re: EXTRA CAPACITY OILPAN W/ HOKKER 2210's
I WAS WONDERING IF ANYONE IS RUNNING ANY PAN OTHER THAN THE MOROSO, A LITTLE HIGH ON THE PRICE, I WAS LEANING TOWARD ONE OF THE CHEAPER PANS ON EBAY, AND IF ANYONE WAS RUNNING THEM AND WHAT KIND OF PICKUP YOU WERE RUNNING
ebay pans are usually made cheaper with thinner metal and more prone to oil pan gasket leaks. Moroso sells a pickup for the pans as well that is a matched set. I sent you a return PM on that oil pan if you're interested.
1 Post
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
x2 for the moroso pan. Mine is a deep pan w/o the kickout. It lists in jegs and says it's for 82-92 f body's. I too got the pick up with it.
Car: Used to drive a camaro
x3 on the 6 qt Moroso 82-92 Fbody pan. Do yourself a favor and spend the extra money on a decent pan, really most of those ebay pans are pretty cheap on the qual.
p.haze92
12-20-2006 06:05 AM
