Need Direct Fit 3" Catalytic Converter For 2055 Headers/Y-Pipe
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I am in process of purchasing the 2055 headers from Jet-Hot with air tubes removed and plugged with 3" y-pipe fully ceramic coated along with a GMMG cat-back.
I asked Jet-hot because I still need to go through emissions to get plates for my car that I needed a 3" direct fit cat and they said as long as you get one that fits the stock location and size but is 3" everything should go together perfect..
I CANNOT GET TO AN EXHAUST SHOP
So I have to have my exhaust completely fit...I know the cat-back fits to stock location, and also the y-pipe to the 2055 fit to the stock location, but what 3" high flow cat will mate to both of these systems?
I have only 1 cat I feel will fit http://store.summitracing.com/partde...part=MPE-93441, but it has no bend and says its a direct fit(I know pictures dont always represent actual product, but want to make sure)...I need BIG help because I dont want to order the wrong part or even order these up and never find a perfect fit...or at least close to.
PLEASE, THOSE WITH THE 2055 HEADERS AND Y-PIPE PLEASE LET ME KNOW WHAT 3" CAT YOU USED.
Part # Please
Part # Please
Car: 89' IROC-Z
Engine: LO3
Re: Need Direct Fit 3" Catalytic Converter For 2055 Headers/Y-Pipe
That was quick....haha
Do you happen to have pictures of your setup?
You didnt need to use any extensions or had to cut anything did you?
https://www.thirdgen.org/forums/atta...please-cat.jpg
JamesC
Car: 89' IROC-Z
Engine: LO3
ALRIGHT....thanks man, appreciate it alot. Especially since I am sure in the future someone will ask this who also cant get to an exhaust shop...
P.S. I commented your VB Garage
Silver is oh so sexy.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Seriously, you search on "2055", and it won't take all that long to find "Catco 9118" within a thread.
Hey, I've got one, too!!!!
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
How much do these cats flow? I mean, what is the flow rate?
1 Post
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
That magnaflow cat looks to be the same thing almost exactly, for a lower price. That should work too, right?
Another question I had is, how do you tell if a cat is "hi-flow" it doesent say anything about it on summit.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The GMMG won't reach the Catco 9118. I have both.
Exhaust shop used a tiny piece of my old Flowmaster intermediate pipe to connect the GMMG intermediate pipe to the cat.
Basically the GMMG doesn't bend where the cat is.
Car: 89' IROC-Z
Engine: LO3
Hmm, anybody know about BORLA then? Haha, its either them or flowmaster but looking for that SS and throaty sound. I'd call Borla and ask but its the weekend....
Thanks pal.
Thanks pal.
Perhaps you've already investigated the Hooker catback (Summit HOK-16823HKR) and discarded the idea, but it's right up this old fart's alley: nasty growl at WOT, but mannerly enough at cruise to allow conversion and/or music. As a plus, it's a direct fit.
For what the link's worth:
https://www.thirdgen.org/forums/engi...fler-back.html
I appreciate your comments in the garage.
JamesC
JamesC
When I got my 2055's for my car, I found the Y-Pipe didn't have the 4-bolt flange needed to bolt up to the Cat, I had to cut the 4-bolt flange off my old stock Y-pipe (from my exhaust manifolds) and have it welded onto the new y-pipe so I could bolt it to the cat.
Hope this helps.
By the by, did anyone else find they needed to weld up the 4-bolt flange or did your's already come with one on it?
Hope this helps.
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
The 2055 Y doesn't come with a flange. The L69 Y/Cat has the 4-bolt, of course, so if you wish to keep the OE cat, welding is required. Many chuck the OE for a no-muss, no fuss three-inch system like the following:
JamesC
JamesC
Slip fit to the Y. The pic isn't too great, but you'll get the idea.
JamesC
JamesC
JamesC
JamesC
1 Post
Engine: LO3
Anybody got a sound clip of the hooker catback on a LO3?
1992 Trans Am
05-10-2023 07:19 PM
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
1992 Trans Am
08-08-2015 08:16 PM
