dual tip mufflers
1 Post
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
dual tip mufflers
I want to have quad exhuast out the back, but i don't want cheezy dual tips. I want to have to mufflers on each side of the gas tank, that have to nice dual tips coming out of them. The only mufflers i can find like that are like borla ***** mufflers though. Aren't ***** mufflers just mufflers that echo more than they muffler. Would these sound good on a V8? And if anyone can find the type of muffler i am descirbe please let me know.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: dual tip mufflers
not totally following you. So your looking for mufflers with tips built right onto them? your pretty much limited to "asian food that goes with anything" type mufflers. Other than that, there are millions of mufflers out there with 1 inlet and 2 outlets, then you could choose you own tip. Flowmaster make a shat load of them BTW.
why is ***** blocked? it offensive, just like **** **** *** ***** **** ect.... did you not read the stickies/board rules?
Last edited by //<86TA>\\; 12-31-2007 at 01:40 PM. Reason: they are, and were only ever stars
1 Post
Car: Iroc
Engine: 350 4-bolt
All the dual outlet mufflers have the outlets spaced out. I want my tips to be right next to each other.
So how will an exhuast built for 4 cylinders sound on a v8?
haha um.... i never got around to it. :P
1 Post
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Search for pics of the hooker aerochamber cat-back.
http://video.google.com/videoplay?do...arch&plindex=6
1 Post
Car: Iroc
Engine: 350 4-bolt
here are the mufflers i want, but there made for imports i think. Do you think they have a good sound for v8s?
ill take a look at those too.
1 Post
Engine: LO3
You could run those mufflers. I think they would just sound OK. They are basically a y-pipe and glasspack all in one. I know, because I had them on my v6 monte carlo. They sound like **** on a 60* motor, but on a v8 the would sound alot better.
If you dont like the hooker tips look, and want the glasspack sound, here is what I would do:
have the exhaust shop run you a 3" cat back system in the stock tunnel. Between the catalytic convertor and the rear axle, put a cherry bomb glasspack under the floor
![](http://www.jegs.com/images/photos/glasspack.gif)
after the pipe goes over the rear axle, have them make a custom y-pipe and run two of these tips out
![](http://www.completeexhaust.com/images/35168.jpg)
It will sound alot meaner than those rice mufflers by 3Aracing, and it will be cheaper.
1 Post
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
The borla XR-1 sounds excellent in the "loudmouth" style system(like the one above.
And the packing in the glasspacks will burn out eventually and turn into nothing more than a hollow tube.
Car: 1988 IROC-Z
Engine: LB9
1 Post
Engine: LO3
Those cherry bombs are cheap enough at pepboys, that when it started to rust/ get blown out , you could just buy a new one and get it welded in for like $50 bucks. My cheapo DTM glasspacks lasted about 2 years before they started to sound "hollow." But the tone definately does change over time as they break in.
1 Post
Car: Iroc
Engine: 350 4-bolt
im gonna run mid headers and a gutted out cat... will that help my sound with the 3A Racing? I really like the way they look. Also, do you think they will have good flow?
Car: 1988 IROC-Z
Engine: LB9
Hotrodboba400
12-10-2019 07:07 PM
88SS6SPEED
11-11-2015 07:05 AM
