dual cat y pipe worth the money?
Do you gain a lot from those dual cat y pipes? Are they worth the price? Was thinking of one for my stock 90 RS 305 to gain just a little punch.
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
Re: dual cat y pipe worth the money?
Pick up a good quality single cat Y-pipe, they flow better and are lighter than the factory dual cat pipe. Just be sure to match it with a good hi-flow cat.
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
your stock y pipe with that "T" intersection where the pipes merge is the worse design ever. an aftermarket single cat y pipe would be better, but the dual cats flow even better.
being lighter, yes but maybe at about 10-15 pounds TOPS. since there is an extra cat and maybe 3 feet of extra pipe. but the performance increase would be worth a few extra pounds.
if i were you i would look into a catback before the y-pipe, or for even more power get some headers, y pipe, and a catback.
Car: 92 Trans Am
Transmission: 4L60
Anyone have flow numbers handy on this one? I know I have read it in the past (not on here though). Wish I could remember where. What I read stated that, yes the factory dual cat y pipe out flowed the single, but an after market single outflowed the dual cat set up.
LT1Formula
20
11-14-2015 12:02 AM
