True dual, lowered 3rd gen..just look!!
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Well there it is. True dual on a lowerd (2 1/2 inches) 1985 Trans Am. Hooker long tube headers to 2 1/2 oval exhaust pipe. One small frame notch gave me the room I needed, And some fancy welding got it over the rear. The only part of the system anywhere near the ground is the header flange. About 2 inches off the pavement. lol Im gonna hope for the best. Everything else is tucked up nicley. Still trying to figure out a muffler. I have plenty of room for 2 mufflers. But fornow i merged the 2 ovals into a flowmaster. I just want to drive it.lol Let me know what you think
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: True dual, lowered 3rd gen..just look!!
thats sweet!!..how much did that end up costing?
Transmission: t-56
It only cost me about $570.00 for the diffrent bends and straight sections. If i go into more detail. Figure 2 4 1/2 inch flap disk for gringing the pipes, About 5 cut off wheels at 2 bux each, weld wire and some argone gass. About $600 bux. Oh and for now i have reused my flowmaster, Till i find some nice cans. Ill try to get some more pics up soon.
Transmission: t-56
[IMG][/IMG]Well Think of it as a large x pipe. X pipes merge to one . The pipe was cut in half and a bigger section welded to it. Theres only a 6 inch merge and its 4 1/4 wide.
It's my understanding that TRUE duals means that there is ONE pipe runnning from each header and they never meet.. Now adding a X pipe or a H pipe confuses things a little, and its purely opinion if you think its still TRUE dual or just a dual/twin system.
There is no denying that the system posted here is a dual setup.. but I think you guys have lost the meaning in "TRUE DUALS" since the term is tossed around all the time.
Anyway, thats a great DUAL setup
Transmission: t-56
Yeah i guess I would have to agree with you that in a sence there are not two seprate pipes. It does merge on my set up. I wanted to balance the exhaust flow a bit. There is just enough room to run 2 pipes in a similar fashion without distroying your frame rails. I searched and searched for pics and discriptions of eveyones set up on these cars. Everything I saw was just too complicating or looked hacked up. Hopefull it helps at lease one person to get a better idea of what could be done. I should have more pics up soon of it on the ground. And shortly some dyno #s to see if there were any ganes after doing all that.
1 Post
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I know this is an old thread, but maybe the original poster can log on to photobucket and have an active account so we can see the pictures again. I am looking to see what part of the frame you notched and how it was done.
probably cause morons keep bring up threads from 2 years ago.
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
The last time the OP was online was 8 months ago.............I wouldnt hold your breath waiting for the pics.................
Transmission: t-56
This is a reall old post, but my set up is kinda still the same. only diffrence is that i tucked my headers up into the vehicle about 2 inches for ground clearence.
Ive been looking into the spohn stainless headers, anyone have them? How do they fit? Performance?
Car: 87 Iroc Race car, 71 Z/28 Race car
Engine: 5700cc self built
Transmission: Muncie 4 speeds
Axle/Gears: 3.75/3.5
Blimey I wouldnt fancy cutting the frame like that, whats the point in puttin in frame conectors etc if you are going to muller it like that?
Transmission: t-56
I think with my 10pt roll cage tied into my sub-frame connectors, tied into the front and rear sub-frames, that notch does not feel a thing. A lot of thought went into that notch before it was done.
What type of sub-frame connectors are you using that go anywhere near that front sub-frame point. Even on a triangular brace set up the small bars are still almost 15" further forward then the notch.
The way th notch was done and the exhaust tucked up, I would fabricate a plate and weld som nuts on a plate and onto the frame so that you can bolt the plate under the exhaust. Won't loose a lot of clearance and would certainly stiffen that notch up.
Transmission: t-56
How would you design the plate to cover the notch? The pipes still hang about 1" lower then then frame. I was thinking square stock on its side, weld a plate to that , then drill 4 holes in the corners and bolt it to the frame.
ambainb
04-25-2016 09:21 PM
