Dynomax 2.5" I-pipe to 3.0" I-Pipe
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Right now I have the Dynomax (I think its WLK - 17493) 2.5" cat-back with muffler. I want to upgrade to Intermediate Pipe to 3". Will a 3 Inch pipe slip right over the muffler 'ports' or will i need to get a new muffler to accomodate the larger I-Pipe. Thanks.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Dynomax 2.5" I-pipe to 3.0" I-Pipe
It will 'slip over' with a quarter inch of room around the mufflers input. What you COULD do is cut off the inlet on the muffler, and cut out a 3" hole to match and then weld your new 3" I pipe to your muffler with a fresh cut 3" hole.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
They make flares, shops can usually make anything work usually if they are good.
Err, reducers.
Err, reducers.
This is true too, but I know that the I pipe comes to an abrupt turn to the inlet of the muffler, so would there even be room for it?
Car: 1988 SC Camaro
Engine: 305 TBI
I really don't understand what you're saying...if the 3" I-Pipe will slip over with room, then why would i need to do any cutting or welding?...is the diameter of the muffler port 3" ?
james_fearn
Aftermarket Product Review
07-20-2001 06:46 AM
