Dump off the headers
Location: Houston is where my address is Baghdad is where I work
Car: !988 Iroc-z
Engine: 355 L98 Few nice Mods
Transmission: 700R4 with 2400 stall
Axle/Gears: 373
Has any one tryied to bolt the muffler on to the headers, then just use turndowns off the muffler?
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Dump off the headers
That could be done for sure. It'll be LOUD in the car and out for that matter,but, yeah it can be done.
Car: '92 RS
Engine: 357ci
A 1 chamber Flowstopper would be all that will fit off of shorties. I see shorties is what youre using? That'll make it hard.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You wouldn't be able to bolt any muffler directly to shortys. Long tubes aren't much better with the transmission and front subframe rails in the way.
Car: !988 Iroc-z
Axle/Gears: 373
I've got longtubes on the way. Do you think the bullet type would fit good?
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i am running for the time beeing longtubes and flowmaster 10's and all i have is the headers s pipe and the mufflers on the s pipes and its very loud not much quieter than open headers but nicer sound. i added about 2ft of pipe b4 the mufflers and it made it sound a ton better and a lot quieter in car
redformula88
10-14-2015 06:08 PM
Chad Speier
09-24-2015 12:32 PM
