Exhaust questions about this set up
Car: 92 z28
Transmission: auto
I have a 92 z28. I was planning on getting Hooker 2055(w/ Y pipe) Catco catalytic convereter(Summit #-CTO-9118) and hooker cat-back(summit #-HOK-16823HKR). Has anybody else run this set up or something like it. How much horsepower gain should I expect if I also do some kind of cold air or ram air intake. Will it all bolt in easily, because I can weld.
can the installation be done with jack, jack stands and hand tools? If I am planning on putting on sub-frme connectors, should I putt them on after to give me more room to install the exhaust?
Last edited by Dolfan348454999; 07-15-2007 at 10:09 AM. Reason: Automerged Doublepost
Re: Exhaust questions about this set up
I have a 92 z28. I was planning on getting Hooker 2055(w/ Y pipe) Catco catalytic convereter(Summit #-CTO-9118) and hooker cat-back(summit #-HOK-16823HKR). Has anybody else run this set up or something like it. Will it all bolt in easily, because I can weld.
JamesC
Car: 92 z28
Transmission: auto
I'm looking for a set of jack stands and jack. Most of them come with two jack stands. Is it possible to do the exhaust upgrade with two? It doesn't seem like it would be very safe, but I guess you only ever really need one side of the car up at a time. Sears sells craftsman sets really cheap. Anybody know if they are safe. I dont want the car coming down on me.
Jegs website says that the 2055 headers only fit on camaros up to 1990. Mine is a 92. Will it fit?
Last edited by Dolfan348454999; 07-15-2007 at 01:43 PM. Reason: Automerged Doublepost
Car: 92 z28
Transmission: auto
the catalytic converter isn't supposed to fit either, but the one for my year is 2.5 in inlet rather then a 3 in like this one. Will it work?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i installed my long tubes with 2 jackstands raised to the max.. just make sure to block the tires..
Car: 92 z28
Transmission: auto
Anybody have a heat wrap for the headers to recommend or are they all pretty much the same?
Car: 92 z28
Transmission: auto
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Car: 1984 Trans Am
On a stock 305 you might gain 10 or 20hp on top but at the same time you are probably going to lose some bottom end torque...it is one of those well worth it upgrades though because if you dont free up the exhaust it will choke any HP gains in the future if you mod your motor with cam and heads ect ect.
PS: In the future remember that torque wins races and HP sells parts...lol! You want a nice flat tq curve, you could have a 450hp motor and 200ft pounds of tq and I could have a 375hp motor and 400ft pounds of TQ (Which I have) and I will beat you!
Car: 92 z28
Transmission: auto
is there any exhasut set up that would help low end power, thats really what I am looking for
Car: 1984 Trans Am
Just upgrade your exhaust to a 3" with headers and get a set of 373 or 411 gears as your next mod and you will have a huge smile
Car: 1991 camaro rs
Engine: 305tbi with mods
Transmission: t-5
Axle/Gears: 3.08
im also gonna be running that exact set up, either the hooker catback or the flowmaster, still havent decided
