1 3/4 Header Options
#52
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: 1 3/4 Header Options
Don; i see that you make a nice set of headers + Y pipe
im going to be removing my Edelbrock TES's as they are 8 yrs old and leaking some; and I want a NICE set of headers that will bolt up to my GMPP 350 (same setup as stock) and to my 3"cat/catback which hangs in the stock location
I also want to remove the AIR TUBES and the AIR pump from my car (inspection is NOT an issue), for a cleaner look.
Do you still make these headers/Y pipe that will fit my application (1987 TPI style)
a nice coated/chromed/ set of headers and Y pipe, No iar tubes, bolt right up ?????
PM me if u want to,
Thanks Dave
PM me if u want to,
Thanks Dave
#53
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Dyno Don please respond to me if your willing to sell some headers,just let me now.
Thanks!
Thanks!
#54
1 Post
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
How big are the exhaust ports on his headers? AFR recomends a 1404 exhaust gasket for their heads. The ports are bigger than the SLP headers.
#55
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Does anyone know if Dyno Don's headers have the stock location for the 02 bung.
#57
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
#59
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Do they heat the brake lines up on the driver side?
How much for a set w/out the air lines and a single out Y pipe?
#60
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
so d you really need that big primarys if u wanted 450 rwhp? About 560 crank. If so what is thetighest fitting long tube? I want clearance. Im going to lower my car. If need be i will run shorties but would rather not. Also, will beputting on a lt1 with d port heads it it matters
#61
Am I correct they your collectors use a ball fitting instead of the 3 bolt flat flanges?
Paul
you can email me directly at herrpaul9@yahoo.com
#62
#63
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
Dyno Don, I live in Long Beach and need some exhaust work done. Do you do work on customer's cars? Please let me know. Thanks.
#65
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Don, I am interested in getting a set of your hedders to fit my 88 350 with Fast Burn D shaped ports. How can I buy them?
Paul
Paul
