Looking for stainless steel crossflow muffler.
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What options are there fo a stainless cross flow with a 3" in and 2 2.5" outs? The only one that I have been able to find is the Borla XS part number: 40474.
Is there anything else out there before I buy the Borla?
Thanks,
Thanks,
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Looking for stainless steel crossflow muffler.
Magnaflow
12267 - satin stainless steel
14267 - polished stainless
http://www.magnaflow.com/02product/s...ne=main&id=636
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
There are lots of options.
You can order a Flowmaster in stainless steel, spintech makes them, SLP, and magnaflow. I know there are other but that what come to mind right off the bat.
Car: 87 IROC
Engine: modded LB9
Excellent!
I'm now hovering between the spintech and the magnaflow. More towards the magnaflow at this stage. What is the favourite between these 2 with people out there?
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Magnaflow!!! Quiet when you are sneaking out late at night...and hell at anything above 3000rpms!! Im 100% happy with my system on my LS1. With long tubes and no cats its a little raspy...but I LOVE IT!
Justin
Justin
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I had the choice between the Spintech and the Magnaflow. The Spintech came with my Mufflex 3 1/2 inch cat back. The Spintech is heavy and not of the straight through design.
I purchased the 3 1/2" Magnaflow muffler. It was all I wanted my muffler to be. Quiet while cruising around. Of the straight through design for the most power. Like was said above when the pedal is to the metal it opens up.
Car: 86 Z28
Axle/Gears: TBD
plus one vote for magna flow
get clip here its zipped 305 tpi no cat https://www.thirdgen.org/forums/atta...e-100_0085.zip
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
damn that attachment doesn't work, file is corrupt.
Car: 86 Trans AM
These work... This is through an ORY and long tubes. Motor is a built LS1...that is horrible need of a tune. Not exactly gonna sound the same as a TPI motor..but you get the idea.
http://youtube.com/watch?v=SenLu6531Bg
And a WOT for your listening enjoyment. Watch your headphone volume on this one...
http://youtube.com/watch?v=THMSMZjQrIw
And a vid from inside up to 70... and this wasnt WOT so it gets alittle louder. Im pretty sure I was windows down for this. And I also took out alot of sound deadner up under the dash/pedal area that created a lot more noise.
http://youtube.com/watch?v=Gdji9PETqxA
Justin
Im pretty sure LS1sounds.com has LT1 clips as well...which should sound more like a TPI compared to the LSx motors.
Justin
Car: 86 Z28
Axle/Gears: TBD
check my attachment on the "looking for exhuast check here first" sticky. should be second page. i cant right now as im using my cell to post.
Car: 87 IROC
Engine: modded LB9
Redcamaro,
Thanks for the link. The file works fine for me.
Ghetto,
Is that your car? It looks cool.
I have since ordered the Magnaflow. It worked out considerably cheaper than the Borla and sounds good from the clips I have heard.
Thanks eveyone.
Ghetto,
Thanks eveyone.
Car: 86 Trans AM
RMK,
Yup thats my baby. She is laid up at the moment while I work out some bugs. Im hoping to have a full summer of driving pleasure with her. As well as possibly terrorizing some tracks if I get in on some rentals.
J.
J.
3rdgenparts
05-22-2016 12:50 AM
darwinprice
17
10-12-2015 12:51 AM
skinny z
10-05-2015 07:23 PM
Night rider327
09-25-2015 05:47 AM
