who sells some cheap O2 sensor bung caps
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
Lowes/ any other hardware store....a spark plug will work as well for a temp. patch.
Mike
Mike
For some reason, I am visualizing the spark plug threads being smaller then the thread diameter of an O2 sensor. Hmmm, all well I will give it a try. I welded in 2 extra O2 bungs on my long tube ypipe so it will be easy for a dyno tuner to hook up their wide band setup. I just forgot to order plugs for them and I think there like $10 online a piece.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
advance. go to the aisle with alll the plugs. use a 18x1.5mm differential plug.
works like a champ.
1.98 each.....
works like a champ.
1.98 each.....
LT1Formula
10-08-2015 08:34 PM
efiguy
09-27-2015 01:30 PM
Damon
09-26-2015 04:29 PM
