Hooker cat back system for 350
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
i read the cat back sticky at the top of the page and have decided to go for the hooker cat back system. seems a nice looking system for a good price.
so i go to order and i see that it only gives the system for a 305 ???? ahhhhhhhhh
so my question is why wont it fit my '87 350 ???
thanks, craig
thanks, craig
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Actually give them a call to make sure. You have stock manifolds and y pipe? Do you have a dual cat car?
Engine: 400
Also, If you've got the cash, go with the 4th gen Magnaflow set up.
Here's a video of it on my car.. (it's about 20mb) https://mywebspace.wisc.edu/gmarsice...PG?uniq=as1hs0
Engine: 400
I had a hooker system on my 86 with the 305. I had hooker headers and y pipe no cat and the hooker catback. Sounded awesome, but not as good as the magnaflow
Engine: 350 L98
thanks peps.
i'm order the hooker 16823 cat back system and also the hedmans headers 68470 - ypipe 17470. where the cat was i will be running elctric cutouts , for when i want it LOUD,.
Engine: 350 L98
out of curiosity does anyone know the difference between the hooker 16820 and the 16823
Engine: 350 L98
out of curiostit does anyone know the difference in the hooker 16820 and the 16823 ??
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I called summit on that exact question. One of them has an adapter to go into the catalytic converter, so it got smaller. Since I was getting a 3" high flo cat, I went with the other one. It was just a 3" with no reducing adapter. I forget which exact number was which though. I would call Summit up and ask again, lol.
Engine: 400
That's pretty much right. It's always best to call when in doubt. If you call them you are getting the information from the source. Not from some "dude" on TGO. No offense to anyone.
Engine: 350 L98
yeah cheers guys, exhaust is all ordered up and i will post some video clips when its up and running
