smelly converter?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
smelly converter?
I installed a Magnaflow converter along with a Dynomax 2.5 inch exhaust on my car this spring. I am satisfied with the performance and sound but the exhaust has an awful smell coming off of it after I shut the car off. It's almost like the oil or "newness" hasn't burned off of it yet. It sometimes smells like something's burning- and I'm always checking underneath to make sure nothing is! Anyone ever heard of this?
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Originally Posted by H8TRAFIC
Anyone have a guess at all? I figured after 300 miles the smell would have went away.
lol,
I giggled at the title when I first saw this thread
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
a smelly converter, I thought it was non-sense at first.
Ive never actually exprienced a converter that smelt after
engine shut-off, But something tells me that could be normal
depending on the manufacturer.
I am not running a Magnaflo system, I cant help there..
Do you have any insulation on the exhaust system?
(on headers? or anything that could burn?)
Did anything foreign fall into the exhaust system?
Like a plastic handled screw-driver? I would imagine
that would smelly a but funky
![idiot](https://www.thirdgen.org/forums/images/smilies/idiot.gif)
That was sarcasm, ignore that
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
I actually just put on a Magnaflow high flow converter on my car becuase my old was dirty and would not pass emissions. My car didn't smell when I shut it off, but it would smell when I got on it and led off. Mine smelt like sulfer though, my buddies would be behind me and said they would have to switch lanes. It was bad, anywho, I think that smell is gradually going away, it only does it from time to time now. Perhaps yours will do the same.
Brandon
Brandon
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I have a magnaflow, and yes it smelled like **** for the first 500 miles. All it is is settling the beads in the converter and rubbing it around. Give it awhile and the smell will go away.
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Some of those converters come coated in a plastic wrap and if the tech doesnt remove it before installing it sometimes they can smell. (I work @ a shop that does custom exaust) should go away though.
Thirdgen89GTA
11-26-2015 11:04 PM
