hedmen headers 68470 and y-pipe 17470 o2 sensor install
Car: 82 Firebird SE
I was wondering where you install the o2 sensor on these headers. I was thinking down in the y-pipe right were the 2 come togeather
How do you guys like those headers and the ypipe? They a good fit and good power gains. Im stuck between these and the 2460HKR hooker headers and the y-pipe that goes with it.
Which one is easier to install and more power?
Thanks Alot,
Thanks Alot,
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
imo headers are headers and the installation is the same on these cars... the drivers side is easy, 10 to 15 min and the passenger side is a real kick in nutz....took about 1 hour to 1 1/2.....mainly on putting the bolts on specially the one on the inside and i had issues with the oil dip stick...broke it actually i wonder how everyone else got thru with that and did not bend or break that sucker....as far as power.....exhaust wont give you that much unless you compliment it with a real good intake....then you can maybe get about 10-15....maybe...also make sure you have a good high flo cat and muffler....which there is another issue of preference....anyways....good luck
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
I don't have an O2 sensor, but the drivers side is where it goes. You can put it in the y-pipe if you want, but it is not ideal.
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Originally Posted by sjc115
I had the opposite experience. I have the hedman's and my drivers side was a pain (although only 20 minutes of a pain, went right in after I took the valve cover off for that little extra bit of manueverability) and the passenger side slipped right in (with vavle cover on, and I have no A/C btw). The passenger side bolts were a pain, but nothing that isn't do-able. The drivers side bolts were easy.
HEY just like me. But I had to raise the engine alittle to get the drivers side in.
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
10-15hp? I've heard with nice headers 3" all the way back and an intake you can pick up 30 on a LO3. i guess maybes its just cause its so choked...
Car: 1984 Camaro
Engine: 350, 4bbl
Originally Posted by redlsone
I have a 92 rs that my 305 tbi died in and Im putting in a 383 and I just bought these headers and y pipe. For the price I hope I didnt go wrong.
no green
01-09-2016 09:22 PM
