Should I get rid of my catalytic converter? What will happen?
#51
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Originally Posted by WckdDudeMan
if you tune it right, not all that many people tune these engines right when they make that change... thats why you pull up behind 80s caprice with no cat or a clogged cat and it smells like wrotten eggs... oxygen sensor is picking up a bad reading or out of service engine starts running rich... bad smells happen
#52
Car: '85 El Camino SS
Transmission: Turbo2
I pulled the cat out of my 305 TBI and i noticed a difference right away. Sounds better, drives better, and as long as the pollution ****'s don't take a look under your car it's well worth it.
#54
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
"bad" is relative. I think it smells fine. If it smells horrible (like sulfer) then the cat is clogged. I'm not sure what you mean by "bad"
#55
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
This thread has gone on way too long considering we've already answered the main question quite a few times.
You can either
a) remove it and put some pipe there
b) remove it and replace it with a high flow cat
Since you said you don't have any money, just go ahead and throw the old one in the garbage and put a peice of pipe there.
I hate to be a pessimist about things, but I'm somewhat dubious the cat is your "no power after 3000 RPM" problem. It sounds feasible, but a stock LO3 isn't an Indy race car either. 3K RPM is about when it falls on its face.
You can either
#56
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Originally Posted by Cruz'N Bruz'R
Dude, we drive Thirdgens, we ARE white trash.
#57
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
#59
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I wish I would have seen this before it got out of control.
Removing your emissions equipment is a FEDERAL offense, regardless of your state's emissions regulations. If you are caught, you can be punished by a fine, jailtime, or both. Please stop giving us hot rodders a bad name.
Hotrodboba400
12-10-2019 08:07 PM
