elderbrock TES headers... opinions?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
alright well im looking for some headers i found a guy with a set of eldebrock TES headers with the y-pipe. ill upload a picture of them. the air tubes have been welded shut and the is a little surface rust. lmk what you think. i want headers but i dont want to spend $400 on a set with a y-pipe. i will also be deleting the cat when if i get these any opinions on deleting the cat?
heres the pic what you think? ... cant upload the pic heres the link http://i47.photobucket.com/albums/f1...3/100_0159.jpg
Last edited by maroon88iroc; 03-24-2006 at 06:18 PM. Reason: Automerged Doublepost
Car: 88 IROC
come on guys i know someone has these headers and they'd like to comment on them.
Car: 88 IROC
thanks man i appreciate it. ive never dealt with headers but i would love long tubes unfortunately my car is so low my stock y-pip drags over speed bumps.. lol anyone else want to comment?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
They do look pretty ratty, but not really bad... just have them sandblasted and they'll be good as new.
Car: 88 IROC
ya thats what i was going to do. sandblast and then paint em like bright silver or something. ive heard people have problems with these headers rusting quicker than usual or something. is there anything i can do to prevent that, like a certain kind of paint or primer or something? also i scored them for $85 shipped w/ the y-pipe you think i got a deal?
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I got those headers. I was in the same boat as you. Didnt want to spend $400+ on a set of new headers so I found a used pair. No real complaints here. The y-pipe was a little difficult to get lined up and the last bolt on the passenger side is a pain in the *** to tighten but thats about it. $85 shipped is a nice deal too
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 88 IROC
im kinda worried about them rusting.. i plan on sandblasting them and then painting them with high heat paint. should i wrap them? would that help any?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Exhausts clearance
I have the edelbrock TES header also, decent fit but not great quality, they do rust and are prone to leak at the heads for some reason.
Also, I have a GTA (lower suspension stock) and low profile tires, and my stock exhaust drags over speed bumps. Life in a 3rd gen.
Car: 1987 Iroc-Z
Engine: 383ci TPI
I have them on my lowered 87 Iroc, I had them ceramic coated all the way through the Y pipe. My cat still hangs really low, but not more than stock. I have a larger oil pan so I had to modify the crossover part of the Y slightly. I am running them through a high flow 3" cat and flowmaster muffler and it sounds sweet. When I had them on my old 305 with stock oil pan they fit no problem.
Car: 88 IROC
well i have seen a bunch of people use high temp header paint with good results. im gonna try that first and if it doesnt come out that great ill get them powdercaoted. any idea how much it would cost to sandblast them? and is there anything i could do about the leak problem at the heads?
Car: 1987 Iroc-Z
Engine: 383ci TPI
I used a place in Colorado that sandblasted and did the ceramic coating for like $225 and that was with red and clearcoat on the headers and flat red on the y pipe
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I used high temp paint on my edelbrocks 4 years ago and they still look brand new. Just gotta keep up with em..
Car: 1987 Iroc-Z
Engine: 383ci TPI
High temp paint works, I just like the ceramic coating because it does a nice job on cutting back on engine compartment temp and gets the heat down to the cat. The maintenence is nice too, because there is none.
How old are those? If they're the old design with the 1 1/2" and 1 5/8" tubes then stay away. Yes they're better than stock manifolds but they are much better headers out there.
And DO NOT EVER USE HEADER WRAP!! Sorry to use caps but I cannot stress that enough. Header wrap will trap the heat inside the metal, which gets up over 1000 degrees. The metal will disintegrate at that temp and before long you will have holes in your headers.
I havent had much luck with high-temp paint, either. It always flakes off. Ceramic coating is the best way to go to make a set of headers last.
Car: 89 Iroc Z28
Engine: 350 tpi
Transmission: 700 R4
I had my set coated 2 years ago,and they still look brand new.....Just like Kevin said,do NOT wrap them...I know alot of guys on here don't like them,but then again,what have you done wrong to your car so far.
Car: too many ...
I bought a used set from a member here for around $300 but they were ceramic coated by Chris at CE Coatings (also another member here) so I thought it was worth it. The install was not bad but I haven't had much time using them so no opinion yet on how well they work. The main reason I went with these is because I'm building a motor on the side with 113 aluminum heads and there are a few people on these forums running those heads and the TES system with no problems. I guess because the 113 heads exhaust port loation is a little different from the iron L98 heads (little bit higher) I wanted to make sure I got headers that worked with both heads, and these seem to be the only ones that have been verified (from what I read). My only gripe with my experience is the y-pipe that came with them has a mangled weld on the bottom, not sure if its gonna leak or not. Definately not the fault of Edelbrock or anything, previous owner said it happened at some dealer somewhere *shrug*
Here's the only pic I have so far:
![](http://powerslideways.com/images/tech/headgasket/NewTPI-2.jpg)
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
skinny z
10-05-2015 06:23 PM
