hooker 2210 fitment
1 Post
Car: One of 5
Engine: LB9
hooker 2210 fitment
I really wanted to do a search but tha function is not available yet. Besides the usual ground clearance issues are thare any problmes with these? How about clearance with the K member etc etc? I was planning on using 2460's but the shop that will dyno tune the engine really suggested LT's. I would just buy them direct from Jet Hot and I just wasnted to double check before I spend 640.00 for coated headers.
BTW I am using a Spohn transmission Xmember and torque arm if that matters. Thanks,
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
your looking to do the same set up like i am planing. you are going to have to make a custom y-pipe. mufflex sells a y-pipe for our cars that bolt up from the collectors to the cat but since we are using spohn's tq arm we need to get a custom y pipe made. what tranny are you using. cause i heard of fitttment problems with the manuals thats why i think everyone perfers going with the 2210's i am using a t56 in mine and i have a guy that is going to make a y pipe for me as soon as i am ready
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
They actually contact the A-Arm inside knuckles just a bit. Required a sawzall and carbide grinder to make adequate clearance. It touched the backside of the K-member/engine cradle also but not enough to hurt anything. A mufflex Y-pipe will NOT clear your Spohn cross member perfectly. I had to notch mine a little also to get the y-pipe tucked up properly..OH! and I had to get rid of the damn driveshaft loop. Doesn't clear at ALL with 4" mufflex y-pipe. I'll add one but it'll be custom made...
Just some issues I had. It is well worth it to do this setup still over a shorty/small tube setup. Goodluck!
are you running auto or manual tranny. i have a t56 in mine and i hear of fitment problems with the slave cylinder
no green
01-09-2016 09:22 PM
Chad Speier
09-24-2015 12:32 PM
86White_T/A305
09-21-2015 05:28 PM
