Hedman SHorty Headers
1 Post
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Does Anybody Own THese Headers? DO They Perform Good? I Seen ALot Of Third Gen Owners With Hookers, But Hardly Any With Hedman
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I have the hedman shorties on my camaro. they seem to flow good. I bought the Y-pipe also. Mine are kinda old but they still look like new and they are still quiet(no leaks).
Car: 1991 Trans Am
i have them as well. i didnt know it before i bought them but the y pipe narrows to 2.5 inches. and most people like to go for a full 3 inches. to be totally honest you arent gonna lose much power from that. but then agian it also depends on plans for the car. even a stock L98 will run fine with them. if you can, get the non-emissions legal headers and get rid of the smog crap as it cleans up a LOT of room in the engine bay.
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I used them on my LT1 swap. I like them alot. I put them on when I swapped the motor so I don't know how much of a difference they made. Mine are specifically made for angle plug heads and D-port exhaust. The only problem I have is that the back tube on the passenger side was to close to the heater/AC box and has melted part of it but they are not normal 3rd gen headers. I get a lot of compliments on them because I went ahead and spent the extra $ and got the ceramic coated ones. I had a muffler shop make me a custom 3 inch Y-pipe.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have them and I like them... fairly easy spark plug access with straight plugs (even better with angled I bet), the Y-pipe fits up nice and tight under the car (although mine was cut at the Y to takea 3" pipe), and I didnt have to remove anything to install them, except for the drivers side valve cover. They litterally dropped in. I haven't had any heat soak problems with the starter either, the header on the PS seems to have alot of clearance from the starter. They perform really well too, although I haven't tried anything else in this car except stock manifolds, so I can't say they are better than any other comparable headers. They made a huge difference on my 350 though, and will be staying on it for some time.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I don't know if you are in a smog inspection/testing area in Wasco, but be extremely careful if you are. Hedman only has two choices for emissions-legal hedders, one each for single and dual cat models (can't tell from your profile which you have). They run in the $350-$400 range. The $250 Hedmans & y-pipe won't cut it.
Car: 1989 RS Camaro
on mine I did think that the pass side was too close to the ac box. I put some of that heat barrier on the box to try to prevent any melting.
Car: 91 Firebird
Engine: 350 Vortec TBI
Axle/Gears: 2.73 single tire fire
I had nothing but problems with hedman headers. I couldnt keep them from leaking and I didnt think they flowed that well. I got alot more flow out of SLP headers and i have no leaks.
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Engine: LS1/LQ4
2.5" on the straight piece with an adapter to 3" to fit a 3" slip-fit inlet cat.
TX-SleeperC5
09-24-2015 03:13 PM
[GA] Shorty headers
Night rider327
09-16-2015 02:20 AM
