cut out, best place?
Old 12-15-2005 | 01:24 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i want to put cut outs in my exhaust when i put my 383 in and i wanted to go with electric. The system i want to go with is hedman longtubes that Y into a single 4in. into a cross flow hooker aero chamber.(basically zz17iroc's setup with a hooker muffler). my question is should i put one cutout at the collector of each long tube or could i just put one in the 4" intermediate pipe.
- can i get a hooker aero chamber thats 4"in and dual 3" out?
Old 12-15-2005 | 06:24 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Heres mine
Old 12-15-2005 | 08:13 PM
MaNiAk86's Avatar
Car: 1983 trans am
im running long tubes though so that doesn't help me.
Old 12-15-2005 | 08:45 PM
Air_Adam's Avatar
If you have longtubes, put the cutouts right on the collectors.
Old 12-28-2005 | 08:53 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
good lord that is low as crap, have you ripped that thing off yet, and is your car lowered??
Old 12-28-2005 | 10:01 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i SERIOUSLY doubt you'll see much gain, if any at all, with longtubes and a properly built y-pipe with 4" exhaust. the cutouts are gonna be a waste of money, plain and simple...it'll be loud enough anyhow.
i do not believe that hooker offers any muffler in a 4" version.
Old 12-28-2005 | 10:09 PM
Air_Adam's Avatar
The car isn't lowered, and its just a bad pic. Its actually got very good ground clearance... better than the factory exhaust system did.
Old 12-29-2005 | 10:33 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I would put 1 behind each header collector.
Old 12-29-2005 | 11:24 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: cut out, best place?
if you're going to run electric cutouts, i would reccomend one cutout in the intermediate pipe.
if you're going to use normal, plate/nut covers on the cutouts, then you can go for the dual cutouts if you want to.
i have dual electric cutouts, and really, its better to just have one motor/butterfly to worry about.
locally, theres 7 guys (including me) that have E-cutouts... i would only get the McCord or the QTP ones..
if you do end up trying dual E cutouts, put the cutouts far back as possible to keep them from the heat. while the acutal cutout isnt damaged, the copper RTV that makes the final seal will dissappear otherwise... and you'll have a tiny, annoying exhaust leak when closed.
Old 12-29-2005 | 11:52 AM
Air_Adam's Avatar
Re: Re: cut out, best place?
Originally posted by MrDude_1
...while the acutal cutout isnt damaged, the copper RTV that makes the final seal will dissappear otherwise... and you'll have a tiny, annoying exhaust leak when closed.
Why not use a gasket, like what a normal cutout is supplied with for the cap? Its baically just a header collector gasket. I use the fibre-type on my cap, and take it off all the time at the track and have yet to have a leak.
Old 12-29-2005 | 01:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: Re: Re: cut out, best place?
im refering to the seal that lets the butterfly actually seal agienst the "bore" of the electric cutout.
unless you put some high temp RTV there, you will never have it seal perfectly... some are tight enough that the exhaust leak never bugs the owner... but it annoys me and others..
McCord does this when they sell it.. im not sure if QTP does, but if they dont, it needs to be done...
yes, you can attach it to the cutout with a normal collector gasket.
Old 12-29-2005 | 10:23 PM
Air_Adam's Avatar
Ahh, ok... I thought you were talking about something else. I stand corrected.
gta892000
08-11-2019 12:16 PM
gta892000
09-16-2015 01:40 AM
gta892000
09-16-2015 01:37 AM
Fox118
09-12-2015 10:29 PM
scottmoyer
09-07-2015 08:06 PM
