breslin header bolts
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
please hellp! I start my used hooker 2055 header installation early next week on my vacation. I'm going with 3/8x3/4 . will this be good to do the job on my 84 lg4. olso need header gasket style or part number to go along with 2055. original set was torn. looking to upgrade the gasket.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The bolts will be fine. You'll need longer ones with spacers the length of the manifold thickness for AC/PS & A.I.R. bracket mounting, if applicable.
FelPro 1404 or Mr. Gasket Ultraseal are what I have used. FelPro for 3-1/2 years with no problems, Ultraseal currently on the car.
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
a/c bracket,alt.bracket
1 Post
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Ummmm. NO. Have someone rev the engine while you watch it torque (twist) in the engine bay. That should answer your question right there.
If you think about it, the only mounting points between the engine and the body are the two motor mounts (flexible rubber or poly) and the transmission mount (rubber or poly). The exhaust is usually held by flexible rubber brackets and the fuel and coolant lines have flexible sections between the body and motor. Now maybe if you were running solid motor mounts, that might be OK, but that's pretty rare. Think what that brace would do as the motor torques...
tom1985
04-19-2016 07:55 AM
LT1Formula
20
11-14-2015 12:02 AM
hectre13
09-08-2015 03:38 PM
