Hooker Aerochamber vs. Dynomax Ultraflo
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I'm curious to know the differences between these two mufflers......
differences as far as sound and performance go
my setup i guess would be long tubes, no cat, 2.5" to the back, single input/single exit
Which will be louder at idle/low RPM's?
...Higher RPM's?
which flows better?
Thanks,
-Chris
...Higher RPM's?
which flows better?
Thanks,
-Chris
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Either of the two will meet the objective that you want. Dynomax mufflers tend to be on the quiet side which some people desire. All aftermarket mufflers flow great but the aerochamber is on the higher side. There are flow charts out on the web somewhere so you can judge for yourself. However, any muffler you choose will be just fine.
I've been told that 2.5" is what I should use, that 3" would hurt my low-end power....
I thought that there really wasnt such thing as TOO much flow, but its what i've been told...
my origional plan was 3", but i dunno
and it'll be single, not dual exhaust
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Someone is giving you bad advice. Go with the 3 inch system. See the chart below from Dynomax. Magnaflow has a similar chart. These are the people who make exhaust systems and have done a great deal of dyno testing. Allen
no green
01-09-2016 09:22 PM
