Headers similar to hooker 2055s but without AIR fittings?
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
okay i was thinking about going with some 2055s in my future buildup but i just saw a picture of them and they include the air fittings. i took off my AIR pump about 3 months ago and i don't want to put it back on either. is there a header around that is just as good as the 2055s but without the emmisons crap on it? and i do need an O2 fitting just not AIR lines, if it comes down to it i could prolly tap my own fitting for the O2 sensor. thankx
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Hooker makes the 2460 with no air fittings, but they've also got no ypipe, at least they didn't a few months ago. Heddman makes a set identical to them except with ball flanges and they come with a nice y pipe. I have the Heddmans that I got from Jet Hot. They were around $300, but I'm a dealer so they'll be around $400.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hooker makes a y pipe for the 2460's i finally got mine yesturday. very nice piece. cost $205 shipped but it was on back order for awhile.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
too bad i don't plan on using a y-pipe . gonna make it true duals with glasspack style mufflers (not acutal glasspacks), should sound pretty mean
thankx
thankx
Car: 1985 Iroc-Z
Transmission: t-5
I bought the 2055's and cut the air tubes off and welded up the holes. Any place that welds could do it real easy and wouldnt cost much.
Engine: LB9/383
thankx
thankx
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may want to look at SLP's then. They sell of their headers in AIR and non-AIR versions. You may also want to look at the Mac's that have only a thin single AIR tube instead of the alien stock version that comes on most smog headers.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i'll have to look into those SLPs, and welding would not be a problem at all seeing as our shop has 12 mig and 6 tig welders. and i would go with longtubes if it wasn't for the clearance issues, back home in mass i live in a very hilly city and i don't need to be wrecking $400 headers. thankx guys
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
you make a valid point, i'm gonna eliminate the standard muffler in hopes of gaining some clearance there. i guess i'll just have to be careful and drive slow over bumps.
ambainb
04-25-2016 09:21 PM
evilstuie
02-28-2016 03:33 PM
