exhaust manifold bolts loosen up...
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
i've got a chevy 350 w/ headers and the bolts holding the header on loosen up causing exhaust leaks. I've heard the recommendation is to put lock-tight on the bolts, but I saw there was many different strengths of lock-tight. I want the bolts to stay in but wanna be able to get them off at some point.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Loctite isn't going to do much good in that kind of heat. Locking header bolts or lock wire would be best.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What I did, was order a set of header bolts drilled for safety wire. Basically, the bolt heads have small holes drilled through them so you can feed some tie wire through, to basically tie the bolt in place. It works very well.
The bolts were about $35 cdn for a set of 12. I dunno how much that is in US currency.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may want to look into a locking header bolt. The breslins are a great product and don't use locking tabs like the Stage 8's do.
Engine: Chevy 350ci
i've actually never heard of a lockwire or safety wire solution to the problem. is it possible for a more in-depth explanation on how that works?
1 Post
transaero
08-31-2015 01:14 AM
