hedman longtubes and t56
i have a t56 from an lt1 camaro and i used hedman tork-step long tubes, they have a 3 bolt 3inch flange. you can spin the flange to the thin side and you will have to grind on the bellhousing and the flange. i had to do some grinding on the starter side of the bellhousing to use my stock full sized starter.
hope this answers your question
later,
Jon
later,
Jon
mw66nova the long tube mafia hahahah!
Jon i hope you got my mail...!
Are the hedmans so rear??????only 3 people ...can sombody shoot me the part number from the LT hedman´s????
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Does anyone know if ill have problems with the 68466 hedmans?? I have a t56 and was hoping hedmans would just fit right in
Nova, does the 68460 hedmans fit with a t56? im looking for the best fitment header, and the best ground clearance.
Car: 91 Z28
Engine: Lt1
the problem with the 2210's are they hang to low and I scrape now I can only imagine what its gonna be like with the hookers.
alright, here's what i've gathered running hedman longtubes (of any sort, they are all dimensionally the same) with a t-5 or t-56. the collector rubs the bellhousing and slave cylinder so you have to do a little grinding on the bellhousing, and dent the collector.
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
yes you could do that with the old style collector. now all they selll is the ball and socket style flange! I just bought a set of the heddman lt's and im trying to figure out how to make them work with a t-5?
bigjay89gta
10-15-2015 08:04 AM
