Electric cut out, Leaking yet?
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Tried seaching, but im getting alot of those pages not found thing, so i ask,
People with the electric cut outs, are you having sealing issues with them, i see they have been around sence atleast 03, im getting ready to plan out my new exhaust, and i was wanting to install an electric cut out, but i dont want it seeping, and hissing while its supost to be closed, the QTP and McCord sites didnt have any specifics on the sealing part of them.
Also its going on a carbed 350, with LT headers, probly will have cut out right after Y pipe, if i get it tuned to run with it closed, will i be in danger of leaning it out too much when i open it up? Or should i tune a little rich before hand?
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I got mine in one of the last group purchases from McCord. It's the PowerPlate II, or at least I think it is. Mine hasn't started leaking yet. And as far as Lean or Rich, I haven't noticed any change on my A/F Ratio gauge when it's open. I could be wrong, but I can't see a cut out effecting air/fuel mixture.
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
The reason i bring up the leaning issues, is that when you change your exhaust your lessoning backpressure. Generaly when a burned mixture is exiting the cylender, it is still overlaped with the fresh mixture, ive read before that the old is usually passed by the carb by kind of a back flow, having more fuel added.
Or, not all the exhaust gets out with restictive exhaust, holding in some unburned fuel, witch lets say you get that out, and all fresh comes back in it changes the AF ratio, or so ive read.
I maybe going nuts here, but i know you have to tune your motor with just a header swap, if you want the most out of it, usually adding fuel to the now lean mixture.
You maynot be noticeing anything becuase you have an EFI system with an O2 that can correct for some of the leaning.
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I haven't had any problems with sealing. And I didnt even use RTV to seal it to the cutout, I just used a gasket.
And I dont have an a/f guage yet, so I dont know about my mixture. I think it's leaning out though.
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
your supposed to use rtv where the part opens and closes, open it up and put some all around the opening part and then close it and let it dry, my dad has two in his 77 ta and doesnt have any problems.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've had mine on for almost 2 years now. If I crawl under the car...I can hear it leaking just a little...other then that..it's fine...can't hear it leaking at all while sitting at idle or anything..
Engine: 5.7
Originally posted by Project
My buddy has some on a carbed TA and they leak horribly...after a year...rust all over the plate...
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Car: camaro rs 305
Engine: 305 slow tbi
Transmission: slow aut
just read my post on quick time performance
they suck, better crowlll under and spend the extra 20 callories, thrust me our hands work way better
db057
08-11-2015 10:11 PM
